Stuck at 3% during Windows 10 ISO File Preparation for Installation
Pr0moK 6954 7
  • #1 17021666
    Pr0moK
    Hello, I want to install w10 from a disc (ISO from Microsoft) everything goes well up to the preparation of files for installation and stands at 3%. And he can't see her move. I am installing the system because the old C drive was already full (at the first attempt I made the disk format). Thank you in advance for your help.
  • #3 17021689
    Pedros050
    Help: 2471
    Rate: 3927
    @ Pr0moK Hello. Do you install on a laptop or on a computer? Provide RAM specification, processor?
  • #4 17021702
    Pr0moK
    @piterrr_ cpu i5 6600k ram Corsair vengeance lpx DDR 4 3000 Mhz 8 GB (2x4GB) motherboard z170a g43 plus installs on the computer @Killlu download and insert.
  • #5 17021781
    crassman22
    Why did you decide to reinstall the system? If the answer is "began to drastically silence" - check the disk in MHDD, or on some external computer in Victoria.
  • #6 17021926
    Pr0moK
    After inserting the mhdd plate I have something like that. Stuck at 3% during Windows 10 ISO File Preparation for Installation
  • #7 17021942
    Pedros050
    Help: 2471
    Rate: 3927
    Just press Enter, have you changed the disk from AHCI to ATA in the BIOS?
  • #8 17022079
    crassman22
    In the bios, make sure you have AHCI converted to IDE.
    Then you start MHDD, click enter on the option you have indicated, enter the position number under which your disk appears, and double-click F4.
    The scan process should start. Make a screenshot after the process.
The discussion revolves around a user experiencing a stall at 3% during the Windows 10 ISO file preparation for installation. The user is attempting to install Windows 10 from a Microsoft ISO due to a full C drive. Responses suggest checking the disk's health using MHDD, ensuring the BIOS settings are correct (AHCI vs. IDE), and providing system specifications such as CPU and RAM. The user has an Intel i5 6600K processor with Corsair Vengeance LPX DDR4 RAM. Suggestions include using SMART imaging and verifying disk settings in the BIOS.
