Painting the car with a roller with Śnieżka oil and phthalate paint
fotoman125 55341 18
  • #1 18623954
    fotoman125
    Rate: 9
    Hello, I would like to know if Śnieżka oil-phthalic paint will be good for painting the car with a roller, the car has a badly damaged paintwork and attracts attention and I can't afford a painter, besides the car won't drive for a long time I want to paint it so that it doesn't attract attention and my friends said this paint will be good but I would like to know if anyone has already painted it and what roller do I need to get it somehow?
    Does anyone have an idea what color to choose?
    PS: please no stupid comments I know that painting a car with a roller is a stupid idea but I have to paint this car at a cheap cost
    I am asking for a quick answer
  • #2 18624117
    Cowboy zagrabie
    Help: 159
    Rate: 502
    Śnieżka dries for a long time, after drying it does not have the right hardness, it is easily scratched, it is not resistant to UV radiation, it fades and chalks in the sun. Efficiency is also much lower, it takes twice as much to paint the same surface than acrylic varnish. Contrary to appearances, application with a roller is not the easiest method Too thick varnish will leave an orange peel after drying and in the case of this varnish, polishing is not possible due to inhomogeneous pigmentation after drying. Of course, you can cover the trash for half a year, preferably with the same color as it is now, so that in the event of chips, a different color will not come out from underneath. However, it is important to prepare the surface for painting, matting and degreasing it so that the paint does not come off after the first visit to the car wash.
  • #3 18624261
    RobertLodz09
    Level 30  
    Help: 123
    Rate: 542
    Instead of oil paint, I suggest buying a paint called Autorenolak
    it is an enamel based on synthetic resins, technologically and qualitatively higher shelf than oil enamel.
    Autorenolac is a paint that used to be used to paint cars only in connection with the tightening of ecological standards
    it cannot be used for painting cars, therefore it has been requalified and it is written on the packaging
    that it is used to paint metal and other surfaces
    From 20 years ago and more, these are all Polonez Lada Fiats 125 p 126 p and even the so-called. Western cars were painted with it
    As for the roller, it's not so bad to paint the most important thing is to get the right viscosity of the paint so that it's not too thick
    and it spread out nicely when applying it with a roller ;)
  • #4 18624858
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Yes, forty years ago I painted my first series 126, I will not mention what paint, but I did not decide on the roller. An ordinary brush seemed better to me - the surface of the car is small, and there are a lot of different bends. From the preparatory activities, only good washing and degreasing with a solvent. Somehow, it was ok for half a year - then "corrections" had to be made. It didn't look too bad from a distance :)
  • #5 18624921
    fotoman125
    Rate: 9
    ok thank you very much for the answers and do you know what roller to use sponge or some other
  • #6 18625049
    dizba
    Help: 239
    Rate: 808
    The best paint to paint with a roller is polyurethane paint. The boats are painted with it. It is best painted with two people. One paints with a brush, and the other corrects with a sponge roller. Just buy some sponges.
  • #7 18625247
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    Think about another solution, wrapping the car with foil, of course, will be much more expensive than painting with a roller, but the effect will be much better
  • #8 18625286
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    And the car will suddenly double in value. :)
    It's worse when redhead blemishes start to bloom underneath - you won't be able to do much with it.
  • #9 18626054
    decybel91
    Help: 1024
    Rate: 4231
    Depending on how much you want to spend, you can paint it with structural paint for an air gun. I think it's called the Raptor
  • #10 18626207
    E8600
    Help: 529
    Rate: 2520
    Roller painting and paint in the form of polyurethane coatings.
  • #11 18626495
    RobertLodz09
    Level 30  
    Help: 123
    Rate: 542
    Or maybe instead of a roller, this way of painting is a good alternative to spraying your own car, especially since it is a foreign method and not our domestic one ;)
    https://www.youtube.com/watch?v=JUloQWYnNUM
  • #12 18628635
    fotoman125
    Rate: 9
    the car is worth pennies and the raptor will be too expensive the more wrapping with foil I think the matte color will come out quite well after applying it with a roller I don't care about durability so much and it would look like this for about 7 months I was thinking about a black matte maybe some gray matte
  • #13 18628764
    andexp
    Help: 57
    Rate: 278
    When painting with a roller, decent quality is easier to achieve by painting with gloss paint than with matte paint. If you insist on this, choose the so-called. semi-matt This jeep was painted with textured paint, which is different from matt paint.
  • #14 18628781
    fotoman125
    Rate: 9
    and why is it more difficult to paint the mat with a roller?
  • #15 18628923
    andexp
    Help: 57
    Rate: 278
    With a mat with a roller, it is difficult to obtain a uniform surface (it is easy to get streaks), secondly, matte paint is more difficult to keep in a good visual condition, i.e. clean.
  • #16 18629236
    Cowboy zagrabie
    Help: 159
    Rate: 502
    Let me say this .... I worked in a company where the trucks worked on the premises of the plant, but they had to drive a 3 km section on a public road, so they had to undergo inspection and once a year they had to be painted to make them look somehow. Two cans of paint for PLN 25 plus 20 hours of work on sanding and wrapping, and then daily washing for about 40 minutes from the sludge they carried. I convinced one of the ten drivers to get a decent paint job (+ PLN 50 for the material), the rest of the baskets remained the same... He spent no more than 10 minutes at the car wash and after a year the car went for a review without painting. it was acrylic. After a year, all the cars had decent paint :D , the image of the company gained on it and the drivers' hands were rested.
    At the moment, such equipment I would paint with polyurethane.
    If it's a passenger car, then acrylic PLN 80 per liter and you need less than 1.5 liters.
    If van/truck then polyurethane with similar price and performance.
    Snow White you have to buy 3 liters for 25 zlotys and then burn 2000 calories with each wash
    The old saying: the poor can't afford cheap things....
  • #17 18635020
    fotoman125
    Rate: 9
    if the car was worth it, I would choose some decent varnish / paint and I don't care because it will still go for about 6 months anyway and for parts or scrap the car has such a tragic paintwork I don't know what was done to it before by the previous owner so it can't look any worse, I just want it to look somehow and not attract attention, I don't have much opportunity to paint the car with a paint gun
  • #18 21479294
    choinka2
    >>18625247 I covered the bonnet with red foil in May 2024, today the bonnet is almost white. I will also paint with a roller in the spring, it is a waste of money for the foil.
Painting a car with Śnieżka oil-phthalic paint using a roller is generally not recommended due to its long drying time, insufficient hardness, poor UV resistance, and tendency to fade and chalk. The paint requires thorough surface preparation including matting and degreasing to avoid peeling. Application with a roller can cause an uneven "orange peel" texture, and polishing is not feasible because of inhomogeneous pigmentation. Alternatives suggested include synthetic resin-based enamel paints like Autorenolak, which historically were used on cars and offer better quality. Polyurethane paints are considered the best option for roller application, often used in marine coatings, and can be applied with a combination of brush and sponge roller for better results. Matte paints are harder to apply evenly with a roller and maintain visually due to streaking and dirt retention; semi-matt or textured paints are preferable for roller use. For low-budget, short-term solutions, matte black or gray colors may suffice to reduce attention. Other options mentioned include structural paints like Raptor for spray application and car wrapping with foil, though the latter is more expensive and may degrade under sunlight. Practical experience indicates acrylic paints provide better durability and appearance for vehicles subjected to regular washing and inspection. Videos demonstrating roller painting techniques on cars are available for reference.
TL;DR: Need under 1.5 L of acrylic for a passenger car; "The poor can't afford cheap things." For a budget roller repaint, pick acrylic or polyurethane over oil enamels. [Elektroda, Cowboy zagrabie, post #18629236]
Why it matters: This FAQ helps budget DIY owners decide how to roll‑paint a rough car quickly without making it look worse.
Will Śnieżka oil‑phthalic paint work for roller‑painting a car?
It will coat, but it’s a poor choice. It dries slowly, stays soft, scratches easily, and lacks UV resistance. In sunlight it fades and chalks. Expect about 2× the volume versus acrylic for the same area. Thick coats leave orange peel you cannot polish. If you insist, thoroughly scuff and degrease first, or it may wash off at the first car wash. [Elektroda, Cowboy zagrabie, post #18624117]
What paint type rolls best on car panels?
Use polyurethane. It levels well with a roller and is durable outdoors. “It is best painted with two people. One paints with a brush, and the other corrects with a sponge roller.” Stock extra foam sponges so you can switch as they load up. [Elektroda, dizba, post #18625049]
Is Autorenolak a workable budget alternative to oil enamel?
Yes. Autorenolak is a synthetic‑resin enamel that outperforms oil enamel. It was widely used on cars decades ago, then reclassified for general metal surfaces due to newer ecological rules. For rolling, thin to the right viscosity so it lays down smoothly and levels. [Elektroda, RobertLodz09, post #18624261]
How much paint do I need and what will it cost for a small car?
Plan under 1.5 liters of acrylic for a passenger car, at about PLN 80 per liter. For vans or trucks, choose polyurethane with similar price and performance. “The poor can’t afford cheap things”—false savings can cost time and results. [Elektroda, Cowboy zagrabie, post #18629236]
Which roller should I use, foam or something else?
Use a foam (sponge) roller for tipping‑off and a brush to lay paint. “One paints with a brush, and the other corrects with a sponge roller.” How‑To: 1. Load a brush and apply a thin, even strip. 2. Immediately roll lightly with foam to level. 3. Rotate fresh sponges to avoid bubbles and drag. [Elektroda, dizba, post #18625049]
Do I need to sand and degrease before rolling?
Yes. Matting and degreasing are essential so the new layer adheres. If you skip prep, the paint can come off after the first car wash. Proper prep reduces early failure and improves adhesion. [Elektroda, Cowboy zagrabie, post #18624117]
Can I polish a roller finish to remove orange peel?
Not if you used Śnieżka oil‑phthalic paint. Its pigmentation dries unevenly, making polishing ineffective and blotchy. Thick roller coats also leave orange peel that does not polish out well. Choose a different paint if you want to refine the finish. [Elektroda, Cowboy zagrabie, post #18624117]
Is gloss, semi‑matt, or matt easier to apply with a roller?
Gloss is easiest to make look decent with a roller. If you want lower sheen, choose semi‑matt for a safer result. Textured coatings differ from matt and can disguise more surface defects. [Elektroda, andexp, post #18628764]
Why does matte show streaks when rolled?
Matte highlights application marks. With a roller, achieving a uniform surface is difficult, and streaks appear easily. Matte surfaces are also harder to keep visually clean than gloss finishes. [Elektroda, andexp, post #18628923]
What color should I choose to hide chips and avoid attention?
Match the current color as closely as possible. When chips occur, a matching topcoat prevents a different undercolor from showing and attracting attention. [Elektroda, Cowboy zagrabie, post #18624117]
How long might a quick roller job look acceptable?
Expect a basic cover‑up to pass from a distance for about half a year. After that, touch‑ups become likely as wear, chalking, and chips increase. [Elektroda, Cowboy zagrabie, post #18624117]
Are rugged bedliner‑style coatings like Raptor worth it?
They can be, if your budget allows. Structural polyurethane like Raptor gives a tough, textured finish and is applied with an air gun. It costs more than simple enamels and targets durability over gloss. [Elektroda, decybel91, post #18626054]
Is wrapping my car better than rolling paint?
Wrapping delivers a better finish but costs more than rolling. If the budget is tight, rolling wins on price, though the look and longevity will be lower. [Elektroda, carrot, post #18625247]
How does vinyl wrap hold up to sun on bright colors?
One report: a red bonnet wrap applied in May 2024 turned almost white by March 2025. The owner plans to roller‑paint instead of rewrapping. [Elektroda, choinka2, post #21479294]
Can a brush beat a roller on small, curved cars?
Sometimes. On a Fiat 126p with many curves, a brush worked better than a roller. After wash and solvent degreasing, it looked acceptable from a distance for about half a year before touch‑ups. [Elektroda, Gerri, post #18624858]
Where can I watch roller‑painting techniques in action?
See the shared polyurethane roller‑coating videos for step‑by‑step technique and realistic results on vehicles. They illustrate process and finish expectations. [Elektroda, E8600, post #18626207]
