HTC Desire 820 Not Turning On: Orange LED Blinking, Charging Issue, Possible Fixes
wiesio121 11187 19
Why won’t my HTC Desire 820 turn on and only shows an orange LED blinking when connected to the charger after being unused for about half a year?
Check the battery first, because after half a year unused it may be completely discharged, and in a similar case replacing the battery fixed the phone [#16971948][#16972058][#16972071] If the battery already measures about 4.3 V and the phone still shows zero reaction, try entering recovery mode to see whether the system responds at all [#16973143][#16973150] When recovery mode also does nothing, the forum diagnosis was a damaged bootloader [#16973164] In that case, the advice was to let a service center handle it, since repairing it properly requires experience and equipment [#16973174][#16973182][#16973357]
  • #1 16971883
    wiesio121
    Rate: 30
    Hello. I have a problem with my Htc 820. All the time was normally used by me, after some time I put it away and after about half a year I wanted to use it. Unfortunately, the phone does not want to turn on. When connected to the charger, an orange LED lights for about 6 seconds, then blinks and the phone does not start. Can it be fixed? Greetings.
  • #2 16971948
    nutergsm
    Help: 1034
    Rate: 1665
    You need to check the battery voltage.
  • #3 16971966
    wiesio121
    Rate: 30
    I do not have a meter, but the battery was good because the phone worked until the end.
  • #4 16972058
    nutergsm
    Help: 1034
    Rate: 1665
    After this time the battery is completely discharged.
  • #5 16972071
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    A similar case as a user I had
    After replacing the battery, it goes without problems.
  • #6 16972124
    wiesio121
    Rate: 30
    The battery copies because I checked on the language.
  • #7 16972131
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    How much time do you wait from the moment you connect the charger after what time you unfasten? Once you have dismounted it, what is the tension, measure and write. That copying on the language means nothing.
  • #8 16972147
    wiesio121
    Rate: 30
    It's been charging for about 3 hours and no reaction. I do not have a gauge until tomorrow. If I connect it to a computer, it has to read what is in mind, for example, a photo of music?
  • #9 16972564
    nutergsm
    Help: 1034
    Rate: 1665
    Check in the end this battery voltage then we will think what's next.
  • #10 16973112
    wiesio121
    Rate: 30
    The battery has 4.3v should start it but the phone does not respond. What could it be ?
  • #12 16973150
    wiesio121
    Rate: 30
    Zero reaction
  • #13 16973164
    nutergsm
    Help: 1034
    Rate: 1665
    I bet on a damaged bootloader.
  • #14 16973169
    wiesio121
    Rate: 30
    Can you fix it?
    nutergsm
    Help: 1034
    Rate: 1665
    No experience and no equipment, but good service should deal with it.
  • #16 16973180
    wiesio121
    Rate: 30
    What is the cost?
    nutergsm
    Help: 1034
    Rate: 1665
    For this you have to ask the services in your area.
  • #18 16973193
    wiesio121
    Rate: 30
    Can not do it yourself? some program or something?
    nutergsm
    Help: 1034
    Rate: 1665
    You've got the answer before.
  • #20 16974033
    wiesio121
    Rate: 30
    The phone somehow fired. Thanks for the help
The HTC Desire 820 is experiencing a failure to power on, indicated by an orange LED that blinks after a brief illumination when connected to a charger. Users suggest checking the battery voltage, as prolonged inactivity may lead to complete discharge. Replacing the battery has resolved similar issues for some users. Despite a reported battery voltage of 4.3V, the device remains unresponsive, leading to speculation about a damaged bootloader. Recommendations include attempting to access recovery mode and consulting professional repair services for potential fixes.
TL;DR: HTC Desire 820 showing an orange LED for ~6 seconds then blinking usually points to a battery or boot path issue. "After replacing the battery, it goes without problems." Practical next steps: charge, measure voltage, try Recovery/Bootloader, or service. [Elektroda, marqqv, post #16972071]
Why it matters: This FAQ helps owners troubleshoot no‑power and charging faults to recover a non‑booting Desire 820 fast.
What does the orange LED blinking after ~6 seconds mean on the HTC Desire 820?
It indicates the phone sees power but fails to start the normal boot path. Users report an orange LED that lights for about six seconds, then blinks, with no screen activity. This symptom aligns with a depleted or faulty battery, or a blocked boot stage. [Elektroda, wiesio121, post #16971883]
My phone sat unused for about half a year and won’t turn on—why?
Extended storage can deeply discharge the Li‑ion battery below the phone’s safe-start threshold. An expert noted that after such time, the battery is completely discharged. Recharge first, then measure voltage before further steps. "After this time the battery is completely discharged." [Elektroda, nutergsm, post #16972058]
How long should I leave it on charge before I start troubleshooting?
Give it a solid initial charge window. One case charged for about three hours with no reaction, which signaled a deeper issue than simple depletion. If there’s still no screen or vibration after that window, proceed to voltage checks and Recovery attempts. [Elektroda, wiesio121, post #16972147]
How do I check the battery voltage safely?
Use a multimeter across the battery terminals after disconnecting power. Record the reading before and after a short charge attempt. Experts in the thread insisted on confirming voltage first to guide next steps. "Check in the end this battery voltage then we will think what's next." [Elektroda, nutergsm, post #16972564]
Battery reads about 4.3 V but the phone is still dead—what next?
A healthy reading alone doesn’t guarantee boot. One user measured 4.3 V, yet the phone showed no response. Next steps: attempt Recovery/Bootloader, reseat connectors, or try a known‑good replacement battery to rule out voltage-sag under load. [Elektroda, wiesio121, post #16973112]
Could a bad battery be the cause even if the phone used to work fine?
Yes. A helper reported the same LED behavior and resolved it by replacing the battery. If your device won’t enter Recovery and the LED behavior matches, swap in a fresh, compatible pack to test. "After replacing the battery, it goes without problems." [Elektroda, marqqv, post #16972071]
How do I try Recovery or Bootloader mode on the Desire 820?
Follow the standard key combo sequence referenced for this model and try multiple times while connected to power. If it never appears, suspect a non-battery fault. Use the linked Recovery/Bootloader instructions specific to the 820. [Elektroda, nutergsm, post #16973143]
What is the bootloader, and can damage prevent power‑on?
The bootloader is the low‑level program that starts Android. If it’s damaged, the phone can ignore keys, show only charge LEDs, and never reach Recovery. One expert’s assessment: "I bet on a damaged bootloader." Seek service if Recovery never appears. [Elektroda, nutergsm, post #16973164]
Can I fix a damaged bootloader at home without special tools?
Not realistically. A technician advised that without experience and the right equipment, you should let a good service handle it. They have the interfaces and firmware access necessary for bootloader repair or reflash. [Elektroda, nutergsm, post #16973174]
How much will professional repair cost for this issue?
Pricing varies by region and shop. The recommendation was to contact local services and request a diagnosis quote. Provide the symptoms and any voltage readings to speed triage and avoid unnecessary parts swaps. [Elektroda, nutergsm, post #16973182]
Will my PC detect the phone to copy photos if there’s zero reaction?
No. If the handset shows no response and cannot reach at least the charging or bootloader state, the PC will not enumerate it for file transfer. Data stays on storage but isn’t accessible without a successful boot or specialized service. [Elektroda, wiesio121, post #16973150]
Is there any chance it just starts working again?
Yes, intermittent starts can happen after charging cycles, connector reseats, or repeated key attempts. The original poster later reported, "The phone somehow fired." Treat this as a sign to back up data immediately and still diagnose the root cause. [Elektroda, wiesio121, post #16974033]
What quick 3‑step test should I try before service?
  1. Charge for at least 30–60 minutes on a known‑good charger and cable.
  2. Measure and note battery voltage with a multimeter.
  3. Attempt Recovery/Bootloader using the model‑specific key sequence.
    If any step fails, consider a replacement battery or service. [Elektroda, nutergsm, post #16973143]
Why do some phones show 4.3 V yet still fail to boot?
Voltage measured at rest can look fine, but the cell may collapse under load due to high internal resistance. That presents as LEDs without successful startup. Treat this edge case by testing with a known‑good battery first. [Elektroda, wiesio121, post #16973112]
What should I tell a repair shop to speed up diagnosis?
Share the exact LED timing (~6 seconds then blink), storage period, any voltage readings, and that Recovery/Bootloader won’t appear. Mention that a damaged bootloader was suspected in a similar case. This helps the shop choose the right path. [Elektroda, nutergsm, post #16973164]
