Beko DIN 15210 Dishwasher Error E02: Troubleshooting, Water Supply & Working Without Salt
Automatxc 53016 6
  • Questioning E02 fault and salt requirement
    #1 16980756
    Automatxc
    I have a question about the dishwasher built-in. I've searched the entire internet and I have not found any specific information (and I do not have the instructions). I installed a jack and a dup. The E02 dishwasher message is displayed as if it wanted to move and then silence.
    I will add that I do not have water under the dishwasher, dry on the lower tray. Snakes are fine and the water is definitely in the wall.
    And one more question is whether the above dishwasher will work without salt? This red salt indicator is lit (although the salt is).
    Thanks for the help
  • #3 17568098
    RRRadzik
    Rate: 59
    I have the same error on the dishwasher. Did you solve the problem?
  • #4 17569955
    ksienciunio
    Rate: 60
    I have the same, the dishwasher fell after 2.5 years from the purchase. Which sensor is responsible for checking the water in the dishwasher? E02 error pops up, and before I turn on the dishwasher it pumps water that is not there. Please, target the sensor. My dishwasher is Beko DIN 26220
  • #5 17631521
    rycerz1980
    Rate: 72
    There is a flow meter on the left side and the sensor is a reed switch.
  • E02 points to a water inlet fault
    #6 19022919
    Amikoo
    Automatxc wrote:
    I have a question about the built-in beko dishwasher. I have already searched the entire internet and haven't found any specific information (and I don't have instructions). I installed a winch and a dup. The message E02 dishwasher is displayed as if it wanted to move and then silence.
    I would like to add that I do not have water for the dishwasher, also dry on the bottom tray. The hoses are fine and the water is definitely in the wall.
    And one more question, will the above dishwasher work without salt? This red salt light is on (although there is salt).
    Thanks for the help
  • #7 19022936
    ksienciunio
    Rate: 60
    Replace the hose and after the trouble. I had it too, damaged Aqua stop valve.
    Salt has no effect here
The discussion revolves around troubleshooting the E02 error on the Beko DIN 15210 dishwasher. Users report that the error indicates a potential issue with water supply, despite having confirmed that there is no water under the dishwasher and that hoses are intact. Suggestions include checking the flow meter and the reed switch sensor, as well as replacing damaged hoses or the Aqua stop valve. Additionally, it is confirmed that the dishwasher can operate without salt, even when the salt indicator is lit.
