[Solved] Mercedes Sprinter 906 (318 CDi) - Error 2624, MAF Sensor Issue, Offset Drift, Boost Pressure
wary2 53961 6
  • #1 16937591
    wary2
    Help: 6
    Rate: 221
    Hello colleagues
    In Sprinter 906 318 CDi I have error 2624 which is described as MAF sensor, offset drift with engine under load.
    I can't delete it. I already replaced the flowmeter with a new one, nothing helped. Maybe something else is causing this error. Please advise.
    Regards
    Once again, I read the errors with texa and a completely different description comes out, i.e. the deviation of the boost pressure at load. However, after deleting, a message about the boost pressure actuator (2510-01) appeared and this is where the problem lies.
  • #2 16938029
    onepiotr
    Help: 55
    Rate: 219
    Did you calibrate it after replacing the flow meter? Just like injections, the air mass sensor, throttle and a few others must be entered through the "start" option (that's probably what it's called).
    Without training, errors will pop up.
  • #3 16965235
    wary2
    Help: 6
    Rate: 221
    I cleaned the geometry on the turbine and installed the turbine actuator repair kit. It runs fine now (no bugs).
    However, I still have one question. It doesn't start on a cold engine, you have to spin it for 2 minutes, and it's just starting to catch on. Then it goes off a few more times and I stain again until it goes, but you have to wait 1 minute. because it does not respond to gas. There are no errors, what could be the reason? It only happens on a cold engine. The fuel pump gives a pressure of approx. 180 bar at start-up. Have any ideas? Maybe injections, but a bit of a strange symptom for them.
  • #4 16965249
    andrzej20001
    Help: 1578
    Rate: 6670
    A bit too little rather.
  • #5 16965255
    wary2
    Help: 6
    Rate: 221
    I noticed that on the starting cables the pressure immediately jumps to approx. 250-320 bar, already at 200 the engine starts. But it still fires up and goes out again and again, behavior like a diesel with air.
    What should the rail pressure be when cranking the starter?
    Strangely, now I walk to the car and it fired from the first time. I tried a few times and it burned, after a while it stopped again, it just fires up and goes out. Pre-pump pressure around 2.5 - 3.5.
  • #6 16967879
    wary2
    Help: 6
    Rate: 221
    Surprisingly, this morning it fired the first time, walked nicely, etc. I turned it off and it did not fire the second time. It's strange, because he doesn't even want to be in the square.
    Now I have mastered how to disconnect the flow meter, it burns without any problems every time. There is 450 mg on the disconnected air flow meter, 220 mg on the connected one. I'll order a new one tomorrow and let you know how it goes.
    wary2
    Help: 6
    Rate: 221
    The starting problem was caused by a faulty fuel flow control valve on the high pressure pump.
    There was no need to calibrate the flow meter.
    Praise from the moderator T5:
    We appreciate you posting a solution to your problem, your topic may be helpful to others. We reward "Helped".
The discussion revolves around a Mercedes Sprinter 906 (318 CDi) experiencing error 2624, related to the MAF sensor and boost pressure issues. The user replaced the flowmeter but could not clear the error. Responses suggest calibrating the flowmeter post-replacement to avoid persistent errors. The user also faced starting difficulties with a cold engine, which was later attributed to a faulty fuel flow control valve on the high-pressure pump. The user noted that disconnecting the flowmeter allowed the engine to start without issues, indicating a potential problem with the sensor itself.
