[Solved] 2.0T F4RT Renault Engine - Knocking Sound, Possible Damaged Pusher, Connecting Rod Bearings Access
ZAHYR 6981 5
  • #1 16905394
    ZAHYR
    Help: 200
    Rate: 179
    I have a question for mechanics who know the F4RT engine from top / bottom :) . I go to such an engine - the symptoms are knocking at idle speed, which increases with the increase in revolutions. It seems to me that the noise comes from above and it is the fault of the damaged pusher, but to get there, you need to unfasten the timing and take apart a bit :) There is also an option for the bottom - the acetabulum.
    I think I'll start at the bottom, the oil is gently dripping from under the bowl, so it will be removed for sealing anyway. Now the question:
    Will I have access to the connecting rod shells and their possible replacement by removing the oil pan?
  • #2 16905451
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    When you remove the bowl, you will have access to the sockets. What is the mileage of this engine. Do not accidentally knock on a loose pin on the connecting rod head. Measure your oil pressure with a pressure gauge.
  • #3 16905565
    kaza12
    I have not met a coincidence
    ZAHYR wrote:
    by removing the oil pan, I will have access to the connecting rod shells
    yet a plastic cover
  • #4 16908182
    ZAHYR
    Help: 200
    Rate: 179
    I will have the car after Christmas or after the new year, then I will measure the pressure.
    The engine has flown over 350,000. The knocking occurs apparently for over 4,000 km (the acetabulum would probably be over after such a time?) Quieter on the cold, louder on the warm.
    jerry1960 tell me more about this pin - have you had any case?
  • #5 16908428
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    With this mileage, everything is possible, A broken connecting rod head can cause a knock, to diagnose this you have to pull the piston with the connecting rod out of the sleeve.
  • #6 17212941
    ZAHYR
    Help: 200
    Rate: 179
    The pusher turned out to be damaged.
