[Solved] Iphone 6 BASEBAND Repair: Bridging Pins, Wire Thickness, BGA Balls, UV Paste in Poland
thelukios 5493 8
  • #1 16905691
    thelukios
    Rate: 15
    Hello, I have a question about "bridging" two pins at the baseband. Which wire / wire should I use to do this? www.youtube com / watch? v = X5uLhL5d5hs & feature = youtu.be at 5:40, what thickness should this cable be? And what BGA balls are best to use to make the iPhone run as long as possible and cold solder is not formed? And where can I buy this green UV paste? What is her name in Poland? :)
    Thanks in advance for your help and best regards
    hacker_ice
    Help: 36
    Rate: 101
    The best wire 0.025mm I do, you can check with me on Instagram how it is made.
    You do not shoot BB through the balls, only through lead solder paste and you must have a strainer to do it.
    In Poland, this is called a Solder UV mask. You must have a good UV lamp to harden (the nail lamp works poorly - I checked it). It's best to buy it in china through ali.
    PS In some cases, the problem in the iPhone 6 is the layout itself and not the path under it. And as it was in old laptops with damaged graphics, when you heat it, it repairs and when it cools it stops working. Sometimes the phone stays on the apple after hatching and re-placing the system.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #3 16908999
    thelukios
    Rate: 15
    In my case, probably only the paths are set free because imei is in the settings and all data (sim works too). Only there is no coverage, and if you enter * # 06 #, no imei will be shown. I wonder if maybe ipradge to ios 11 will not solve this problem but I prefer to stay with my 10.3, the apple page is written to update it in case of such a problem but from what I see on the net this update does not help.
    On the net, I see that BB can be normally shot, some make balls with the other paste, so I come to the conclusion that it makes no difference.
    hacker_ice
    Help: 36
    Rate: 101
    Yes, balls or paste is no difference, simply paste is easier because here and here you need to have a sieve, usually with balls use one that is only for 1 system in such a special mount so as not to lose balls.
    From what you write, it's rather only the paths have gone, I usually have 6 Plus that when it comes to touch, sometimes the range flies and I have to do BB.
    Apple Surgery
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Preferably such a matrix, such a wire and paste you do it in 2 minutes you do not have to fart with balls.
    link [/ Code]
    Using solder paste stencils and uFL braid for baseband repair
    #6 16912143
    RafalB
    Help: 91
    Rate: 222
    You make balls from tin paste, strainers / matrices as from the link above, they are a bit expensive but I have all from 5s to 7plus, I found them although I used to hate them ;)
    [Film: 36ecdf8d8f] https://filmy.elektroda.pl/91_1514194382.mp4 [/ film: 36ecdf8d8f]
    Ball shot effect using paste and strainer:
    Wire, unfortunately it's hard to buy the right one, people use a wire from the iphone speakers or a wire pulled from a damaged vibration motor.
    Personally, I use uFL braid
    The effect below:
    The green soldermask looks nasty, my eyes bleed when I see it on a dark laminate.
    You can buy any color from a Chinese, suggests using colors that match the color of the laminate :)
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
  • #7 16927113
    thelukios
    Rate: 15
    And such a question about a wire :) is there anyone from Silesia and I could buy this wire from him for a nominal fee; p or by letter will be ok. Because I can order from here (https://multi-com.pl/,details,id_pr,21666,key, copper-winding-wire-for-repair-path-0-02-mm-50m, smenu, service_tools.html) but it comes out PLN 40, I'd rather give someone some money and give me a few meters of it; p they have a margin of over 65 %, I would order on alliexpress but time ....
  • #9 18376025
    thelukios
    Rate: 15
    Thanks again to the people above for help :) I know a lot of time has passed :) ))
    Regards, the topic is considered closed :)
The discussion revolves around the repair of the iPhone 6 baseband, specifically focusing on bridging pins, wire thickness, BGA balls, and UV paste. Users recommend using a wire thickness of 0.025mm for bridging, and emphasize the importance of using lead solder paste instead of BGA balls for better results. The green UV paste, referred to as Solder UV mask in Poland, is suggested to be purchased from Chinese suppliers, as local options may be limited. Participants also discuss the challenges of repairing paths and the potential need for a good UV lamp for curing the paste. Additionally, users share sources for purchasing the necessary wire and tools, highlighting the difficulty in finding the right materials locally.
