Soundbar - How to connect LG TV 49LH541V to the soundbar and LG SH4D soundbar
majka1508 6039 7
  • #1 16905753
    majka1508
    Hello, I would like to connect a tv LG 49LH541V to the soundbar and LG SH4D strip but I do not know how because I do not have a TV optical input. And the strip only has such an input.
  • #2 16908246
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    Is there a euro jack on the TV? Please, place pictures with the sockets of the TV set.
  • #3 16908569
    majka1508
    Yes, and USB input.
    • Soundbar - How to connect LG TV 49LH541V to the soundbar and LG SH4D soundbar IMG_20171221_092404.jpg (1.2 MB) You must be logged in to download this attachment.
  • #4 16908687
    Polon_us
    Help: 1184
    Rate: 1281
    Does the TV use a built-in tuner?
    Are any other devices connected to the TV?
  • #6 16909044
    Polon_us
    Help: 1184
    Rate: 1281
    nomudrek wrote:
    The only way out is to use a Bluetooth transmitter
    Certainly the only one?
    After all, you can use the ADC converter - analog to digital signal in combination with the signal from Euro.
    The snag is that the sound will only be from the built-in tuner (as long as the author of the topic uses it) and external connected analog devices.
    Whether it will be a converter or BT - the same limitation.
    SMART applications will also not be supported by this connection.
    Also the author of the topic must decide for himself.
    The TV, as to put it, is poor in audio outputs and this is the biggest problem.
  • #7 16909186
    majka1508
    Xbox i nc plus.
  • #8 16910370
    Polon_us
    Help: 1184
    Rate: 1281
    Pictures - sockets - both.
    heh ...
To connect an LG 49LH541V TV to an LG SH4D soundbar, the absence of an optical audio output on the TV presents a challenge. Users suggest utilizing a Bluetooth transmitter connected to the TV's euro jack for audio output. Alternatively, an analog-to-digital converter can be employed, but this will limit sound output to the built-in tuner and connected analog devices, excluding SMART applications. The discussion emphasizes the need for additional cables or devices to facilitate the connection.
