Sounbar LG LAS655K with TV Thomson 40FB5416 - trouble with connection
goomen 4389 11
How can I connect an LG soundbar to a Thomson TV when the TV has no optical output and HDMI ARC does not work?
Use the TV’s coaxial digital audio output (S/PDIF) and connect it to the soundbar’s optical input through a coaxial-to-optical converter [#16274630] If you still want to try HDMI ARC, make sure T-Link/ARC is enabled and the HDMI cable meets at least HDMI 1.4a, but in this case ARC did not pair even after resets and a Thomson software update [#16274630] [#16275984] [#16276938] The practical solution reported in the thread is the converter, since the TV/soundbar combination would not work over ARC [#16276938] The converter does not mean a real audio-quality loss, because it only changes the transmission method between digital interfaces [#16277093] [#16277274]
  • #1 16274506
    goomen
    I have a problem with connecting the LG sounbar to the Thomson tv, namely the problem is that there is no optical output on the tv. Attempting to connect via arc padel ... i.e. no sound on the speakers with the tv All I can do is enter the sounbar menu on tv.
    Does anyone have any idea how to connect this to make it work?
  • #2 16274630
    Polon_us
    Help: 1184
    Rate: 1282
    According to the description, the TV has a coaxial digital audio output, the so-called "electric". Described on the TV as S / PDIF.
    To connect them to the optical input on the soundbar, a colleague needs a converter, such as in the photo below. No hassle to buy.
    Please pay attention to the description of the converter sockets -> Coax IN -> Opt OUT
    goomen wrote:
    Try to connect via padel arc.
    Just out of curiosity ...
    - the T-Link function on the TV has been enabled?
    - suitable HDMI cable? Meets HDMI1.4a standard or better?
  • #3 16275484
    goomen
    So exactly all the necessary functions have been switched on and the new 1.4 cable is just right. Today I was also in a store where they had the same tv and lg soundbar and it turned out that he was also unable to pair it via hdmi arc. Not much of that, I called thomson and they said it must work. He advised me to download updates from thomson's website because there were already problems with connecting soundbars ... and how much can such a converter cost?
  • #4 16275521
    Polon_us
    Help: 1184
    Rate: 1282
    goomen wrote:
    and how much can such a converter cost ???
    Google not working?
    Heh, for example please see auction # 6572776195 on Allegro.
  • #5 16275674
    goomen
    Thanks for the help. I found out what I wanted ... but it still thrills me that it is impossible to connect as it should be via hdmi arc! Does anyone know why THOMSON doesn't want to pair with sounbar lg via hdmi ???
  • #6 16275984
    KOCUREK1970
    Help: 3865
    Rate: 5498
    So what about that?
    goomen wrote:
    Trying to connect via arc paddle ...
    So it used to be ok and it worked?
    Reset tv and try setup again.
    Can the soundbar also be reset? - if so, do it.
  • #7 16276150
    goomen
    for me it did not work yet because I just bought the lg. On Thomson's hotline they said that it was like that for someone
  • #8 16276237
    KOCUREK1970
    Help: 3865
    Rate: 5498
    What about my other questions?
  • #9 16276938
    goomen
    There was a reset of both ..... still crap !!! I updated the software from thomson and nothing !!!! THOMson is shit with function no function !!!!! The only option is as a colleague wrote at the beginning, i.e. a converter with coaxial optics ....... i.e. loss of signal quality !!!!
  • #10 16277093
    KOCUREK1970
    Help: 3865
    Rate: 5498
    What a loss again? - there will be no loss, it's just another form of audio signal transmission.
    And with coaxial -> OPTICS !!!
  • #11 16277258
    goomen
    It will be a loss because we are switching from digital to analog !!!! I just hope that the ear will not catch it, but the secon is that thanks to the arc you can turn both devices on and off with one remote ... after the conversion, this option will not be anymore! You will have to search for 3 pilots in the living room and sometimes one cannot find each other :P
  • #12 16277274
    KOCUREK1970
    Help: 3865
    Rate: 5498
    The difference between coaxial and optics is the transmission method, audio recoding, etc.
    It's not audiophile equipment - you won't hear any difference.
The discussion revolves around connecting an LG LAS655K soundbar to a Thomson 40FB5416 TV, specifically addressing the absence of an optical output on the TV. Users suggest using a coaxial to optical converter (S/PDIF) to facilitate the connection. Despite ensuring that the HDMI ARC function is enabled and using a compatible HDMI 1.4 cable, users report difficulties in establishing a connection. Some users have contacted Thomson support, which recommended software updates due to known issues with soundbar connectivity. The conversation highlights concerns about potential signal quality loss when converting from digital to analog and the inconvenience of managing multiple remotes instead of using a single remote for both devices.
