TV LG 42LM5400: Connecting External Speakers using Optical Output & Remote Volume Control
maciejczek 7536 2
  • Clarifying optical converter and remote volume control
    #1 16579393
    maciejczek
    I know that a similar topic has already appeared in the forum, but I did not find the exact answer.
    I have a tv LG 42LM5400 without headphone output. I would like to connect external speakers to the TV.
    Outputs I have on TV:
    I tried to connect the sound through Cinch, I also bought an EURO to Cinch adapter and everything does not work - there is no sound.
    In TV options, I can set the optical output as sound output.
    I know that I would need a converter, now the question is, if I connect such a converter, will the remote volume control work?
    arturdip
    Help: 170
    Rate: 324
    This euro connector looks like I / O (at least marked like that) so with a 6x cinch euro cable there should be a signal on the labeled cinch (output). There will be no volume control.
    Polon_us
    Help: 1184
    Rate: 1281
    No, it won't work.
    Topics from recent days - just read carefully:
    link . link
