Iveco Turbo Daily 50C13 - Yellow key indicator light, the engine does not turn
lechpolda 12783 2
  • #1 16908908
    lechpolda
    After turning the key, the indicator light with the yellow key lights up and the car cannot be started, the engine does not spin. What could be the problem?
  • #2 16908976
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    The problem with the immobilizer. You have the second key.
  • #3 16909001
    jacekwwy
    Level 19  
    Help: 39
    Rate: 108
    This is an indicator from the immobilizer, try to fire from the spare key, charge the battery
    Iveco Turbo Daily 50C13 - Yellow key indicator light, the engine does not turn Iveco Turbo Daily 50C13 - Yellow key indicator light, the engine does not turn Iveco Turbo Daily 50C13 - Yellow key indicator light, the engine does not turn
    I am not sure this manual will fit your model
