Cyber Ghost VPN 6 Reviews: Worth Installing for Network Security Improvement?
artekideapop 4140 9
Should I install CyberGhost VPN 6 to improve my computer's network security?
CyberGhost VPN 6 seems only partly useful for privacy, and the thread does not present it as a clearly worthwhile security upgrade: one reply says it has weak servers and long queues on the free tier, so it is not recommended [#16915671] Another reply says CyberGhost masks your IP, can bypass regional locks, and is advertised as not keeping logs, but it is described mainly as an IP-hiding tool rather than a must-have for everyday use [#16916460][#16918042] If you want a free alternative, Windscribe was suggested instead, with a 10 GB per month limit [#16915960][#16917203]
  • #1 16915392
    artekideapop
    Rate: 105
    How do you feel about Cyber Ghost VPN 6?
    Is it worth having this program installed on your computer?
    Does it really improve network security?
  • #2 16915671
    makosuu
    Help: 369
    Rate: 370
    Weak servers, queues to connect to a free one, worse than in the PRL. I do not recommend them, they are better.
  • #3 16915817
    artekideapop
    Rate: 105
    Can you give us a better program of this type?
    makosuu
    Help: 369
    Rate: 370
    Windscribe. 10 GB data limit, but I think it's enough for a VPN.
  • #5 16916460
    arcis
    CYBERGHOST
    from Romania
    + do not keep logs
    + pare ip [pl probably 6 Warsaw
    - client brek for linux (ExpressVPN has)
  • #6 16916888
    artekideapop
    Rate: 105
    And these 10 GB is for a month or what? @makosuu
    I still found such a chrome plug:
    Betternet Unlimited Free VPN.
    He writes that no limit, but is it worth something according to you?
  • #7 16917203
    makosuu
    Help: 369
    Rate: 370
    Month
  • #8 16917513
    artekideapop
    Rate: 105
    @makosuu thank you.
    And what about using this program, i.e. when is it best to use it and does it only change the IP address or maybe it affects the improvement of privacy in some other way?
  • VPN masks IP and hides ISP identity
    #9 16918042
    makosuu
    Help: 369
    Rate: 370
    I don't know, I use it mainly when I have some kind of IP ban. And for normal use of the Internet ... I don't know, I don't feel the need. This way, you can bypass regional locks.
    artekideapop wrote:
    Does it only change the IP address or does it affect privacy in some other way?
    It definitely masks the IP, so you are immeasurable, it is not known who the Internet provider is. So it affects privacy. If you want to scam people with a VPN :D
  • #10 16919259
    artekideapop
    Rate: 105
    Thank you ;)
Cyber Ghost VPN 6 has received mixed reviews regarding its effectiveness for network security. Some users report weak server performance and long connection queues, suggesting it may not be the best option available. Alternatives like Windscribe, which offers a 10 GB monthly data limit, are recommended. Cyber Ghost is noted for its no-logs policy and IP masking capabilities, which enhance privacy by concealing the user's internet provider. However, some users express that they do not feel a significant need for a VPN in regular internet use, primarily utilizing it to bypass IP bans and regional restrictions.
