Recommended EU-Based Paid VPN Servers: Top Services, Link Stability, GDPR Compliant
monter79 2763 2
  • #1 17221381
    monter79
    Help: 31
    Rate: 47
    What PAID PARKING VPN server do you recommend? I care about good service, link stability and contact in case of failure. VPN used to secure the internet in the company, + external access to the network. Service in Polish, the company must be located in the European Union, in accordance with the GDPR :)
  • #2 17221623
    m.jastrzebski
    Help: 679
    Rate: 864
    I use vpnonline for private purposes. Fit and flexible, they pissed. Without any problems and combining, I got a fixed IP plus revDNS entries. There is a mail server on a fixed IP address, which is used only by me. In Mikrotik, I can see that the VPN connection works without interruptions for many days. LTE will disconnect more often. Thus, the VPN gets into home resources and for several years it has never happened that there was no access. Generally gendered and forgot.
    What do you mean by "internet security". Because access from outside the company is quite understandable, but having your own link with a permanent address (company ??) you can put a VPN server at home, it will be rather faster.
  • #3 17230763
    CC_PL
    Rate: 57
    The topic is interesting, I would love to hear other people's opinions.
    There are supposedly comparison engines (dobryvpn.pl or pl.vpnmentor.com), but it's good to hear users' opinions.
