Replacement of a single-function gas boiler with a dual-function one
vertuvio 8094 6
  • #1 16509241
    vertuvio
    Hello, I have an old boiler from the 90s installed for heating an apartment in a 3m2 bathroom. I want to replace it with a new dual function. Do I have to take care of any formalities (design, permits, chimney sweep decision) or can I simply replace it without any formalities?
    piotr_boncza
    Help: 135
    Rate: 338
    You can exchange without formalities, but there are a few problems. What is the volume of the bathroom? Measure carefully. It looks like you can only install a condensing / closed combustion chamber. As a precaution, I would also ask the chimney sweep for an opinion if someone was connected to your chimney. Do you have an acid-resistant insert in the chimney?
  • #3 16514438
    vertuvio
    Thank you very much for the hint piotr_boncza! There is no input, the volume of the bathroom is 7.6 m3. Indeed, I have to make a contribution and now the question arises whether I should report it to the community or get any permits? I know that there are different situations with the community and I would not like to expose myself to additional bureaucracy if there is no such need. After all, it is just a modernization of an old installation.
    BUCKS
    Help: 536
    Rate: 1087
    If someone has ever done a fluff it does not mean that everyone will accept it now.
    During the next modernization, you must meet all current standards and regulations.
    So you will probably need a balaclava opinion so that you can make the appropriate replacement.
    Currently, condensing boilers with a closed combustion chamber are popular on the market, moreover, due to the cubature of your bathroom, a boiler with an open combustion chamber is out of the question, but now it is obsolete, so no loss.
    If there is a community there and you do not have an acid-resistant chimney liner, you need the formal consent of this community before installing this liner, so submit an appropriate application for approval now. And if it turns out that your flue has been damaged due to the lack of this contribution, the community may charge you for the potential repair, so officially better not admit that you do not have such a contribution.
    The description shows that you have an old installation, which is why, before connecting a new boiler, it would be necessary to clean the installation, together with the radiators, of sediment and sludge that has accumulated over the years and probably reduced the efficiency of this installation.
    In addition, condensing boilers, in order to achieve the highest possible efficiency, require a slightly lower temperature of the heating water than is the case with an "ordinary boiler", so it may turn out that the old radiators will be a bit too small to take full advantage of the benefits and savings offered by the new boiler .
    In total, I do not know if you have approx. 10,000 ready. PLN or more for the entire modernization, because I have the impression that you are not fully aware of the challenges posed by such modernization. It is certainly not Mr. Pikuś in your case ;-)
  • Choosing boiler and DHW setup for mixed heating system
    #5 19631189
    Suchy_PL_
    Hello, next year there is a general renovation of the lower floor (floor heating) and replacement or rather liquidation of the boiler (garbage) and replacement of the DHW boiler (or rather heater). We did the old installation with my father and it worked for years but I am fed up with shit from coal and woodwork, and my wife wants a warm floor, hence the plans for renovation and switching to a gas stove. The house is 100 years old, about 120m2, insulated in the 90s, but next year a new façade and insulation of the foundations will be made. Currently, I plan to have 6 underfloor heating circuits and 5 radiators upstairs. I did some research on boilers and I must admit that I honestly thought about Termet Ecocondens Gold Plus 25 (but here is something low efficiency compared to others, so probably higher consumption costs?) And Bosch Condens GC2300W here a higher price ........ like these boilers work, how with failure rate? is it worth paying extra to Bosch? what is the matter of CWU - do you need a container or will it be able to flow now? currently, about 10s and hot water is flowing, to the bathroom - about 4 meters of pipes to the kitchen - about 6.5 meters. Are CO expansion vessels necessary in this case (of these boilers)?
  • Condensing boilers have similar efficiency; choose hot water setup
    #6 19631228
    BUCKS
    Help: 536
    Rate: 1087
    Suchy_PL_ wrote:
    I was thinking about Termet Ecocondens Gold Plus 25 (but here is something low efficiency compared to others, so probably higher consumption costs?)
    small? ie what you mean, condensing boilers have similar efficiencies, so there aren't any big discrepancies here
    if you take a 1-function boiler, you will have to have a hot water tank, higher cost but better comfort. Or you take a 2-function boiler, you do not need a tray, so lower cost, but the comfort of hot water is worse.
    If you can do it everywhere, it is better to have uniform heating, then the problem of controlling it disappears.
  • Questioning whether a hydraulic separator is needed now
    #7 19689330
    Suchy_PL_
    I decided on 1F Termet Ecocondens GOLD basic comfort controller tank and now I have a purely technical question .... at the moment the stove will be plugged into the old CO installation from the soot ... the old stove will be cut off with valves and its vessel. With only radiators and a storage tank for this season, is it necessary to install a clutch? I am asking because next year, after a general renovation and floor heating, I wanted to give the AFRISO ACB 910 group
The discussion revolves around replacing an old single-function gas boiler with a new dual-function model in a small bathroom. The user inquires about necessary formalities such as design approvals and permits. Responses indicate that while formalities may not be strictly required for the replacement, compliance with current standards is essential. A chimney sweep's opinion is recommended, especially regarding the chimney's condition and the need for an acid-resistant liner. The user also considers various boiler options, including condensing models, and weighs the benefits of different brands and efficiencies. The importance of proper installation and potential community regulations is emphasized.
