DHW Circulation Pump for 150 sqm House, DeDietrich MCR/II 24/28 MI Boiler, and Galmet Fusion Tank
9003 5
  • #1 16606679
  • #2 16606906
    grzeskk
    Help: 319
    Rate: 728
    Pump like a pump. What's more important is what's around her.
    I have UP 15-14 B PM Grundfos at home and it has grown overgrown after two years (it would probably be similar with others). It is important that there are unscrewed valves on both sides, a non-return valve and a thermal trap so that heat is not removed from the tank.
  • #3 16607501
  • #4 16607526
    grzeskk
    Help: 319
    Rate: 728
    For me, it can handle 3 floors, but it basically does not raise, it only forces the flow.
  • #5 16607892
  • #6 16608722
    andrzej lukaszewicz
    Help: 623
    Rate: 2109
    As for the circulation pump, there are many good wilo, grundfoss, Leszno pumps.
    There are wilo models with a check valve. For permanent switching according to the timer I use pumps, e.g. ERGA 3-9W Leszno with capacity regulation. In addition, the above mentioned two shut-off valves with a half-thread and a 1/2 "check valve. I do not recommend a spring-loaded one, it is better to use a flap or ball valve - much lower opening resistance, important for low power and efficiency pumps.
    Do not buy any IBO, omnigen for PLN 200, because believe me: it's a waste of money.
