Payer Program Płatnik 10.01.001: Issues with Obtaining User Certificate & Authenticating Data
Krzysztof Gorski 8043 9
How can I make a user certificate appear in Płatnik so I can authenticate data and send documents electronically?
To make the certificate available in Płatnik, install the software/drivers from the certificate/token provider so the certificate is registered in Windows’ certificate store; Płatnik itself does not search the cryptographic card automatically [#16926840] On modern Windows (7 and newer), this usually works once the provider software is installed, but the ZUS instructions can be out of date or for a different program version [#16927130] If you still get the update/authentication error, one workaround mentioned is to open the form with F8, then Ctrl+O, and change “Range of data downloaded during insured files update” from “Full range” to “No files update” [#16931648]
  • #1 16926809
    Krzysztof Gorski
    Hello! Could anyone of you deal with a user certificate in the Płatnik 10.01.001 program? Follow the guide:
    http://www.zus.pl/firmy/program-platnik/poradnik/zmiany-w-obsludze-certificate-w-programie but I cannot obtain a user certificate and I cannot authenticate the data.
    I go to the Transfer tab -> Electronic transfer settings -> Certificates -> User certificate -> Select -> but unfortunately there is no certificate to choose from as in the guide. Has any of you met with such a problem?
    Regards,
    Chris
  • #2 16926840
    JacekCz
    Help: 760
    Rate: 1463
    It depends on which "provider" you have the certificate, and what windows, the appropriate software must be registered from your card in your windows (this activity has nothing to do with the payer, windows has a "warehouse" or more a list of certificates). Of course, to make it possible, especially on Windows older than 10, reader drivers, etc ...
    The payer will not guess by itself to search the cryptographic card.
    generally the whole sequence is best converted to Win10.
  • #3 16926981
    safbot1st
    Help: 2719
    Rate: 1583
    JacekCz wrote:
    and what windows
    Well, he didn't write. Looking at X it has W10.
    As for the question in the subject, yes, I met. It took me 4 hours to make this "qualified signature" (?).
    I did according to instructions in the email I received from the provider of the USB key (?).
    Interestingly, the manual included items that were not in the program, because they concerned the program in a completely different version than that owned by the "lay" user.
    The description included the use of the 3rd party program and, even more interestingly, downloading the certificate by ... ... a plug-in? For the browser, which worked only in IE, not in eg Firefox.
    I was also groping 40% and I don't remember much about it ...
    I remember that much. Good luck. :P
  • #4 16927130
    JacekCz
    Help: 760
    Rate: 1463
    That will answer, on modern windows (i.e. from 7 inclusive) it never took me a significant time.
    Although I confirm, it never identical with the instructions, because it could not. I need her "more or less" obey with some sense.
    For the last time, what stopped me longer (fifteen minutes?), Until how blind I saw that there are two chronologically versions of the signature (this is correct, e.g. it decodes the letters written to the owner at that time). The payer took the wrong one, even this (indirectly, illegibly) signaled, but blindness.
    Up to and including XP was more work, e.g. sensitivity to periodic update of root certificates, etc. ... it crossed with bank cards, digital tachograph, etc. ... but that's a thing of the past.
    As for toys, in the form of USB it also probably is called a cryptographic card.
    A colleague has a 95% problem with the presence of a certificate in the windows "certificate store", the payer has nothing to choose.
    EDIT: over the years, there aren't even changes that you need to learn in Płatnik (roughly the same features for years), but there are changes deeply for the better in Windows, the old instructions are shooting a cannon fly.
  • #5 16928347
    Krzysztof Gorski
    Sorry for the trivial question, but where to get this certificate and how much does it cost on average? And one more thing, is this certificate necessary if I will personally send the printout to ZUS and not send it electronically?
    I have Windows 10 32bit
    Regards,
    Chris
  • #6 16928519
    Matuzalem
    Help: 1651
    Rate: 1098
    No, unless ... http://www.zus.pl/firmy/sposob-przekazyowania-dokumentow/forma-papierowa
    https://www.elektronicznypodpis.pl/
    https://www.certum.pl/pl/cert_oferta_podpis_elektroniczny/
    etc. etc.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #7 16928526
    safbot1st
    Help: 2719
    Rate: 1583
    Matuzalem wrote:
    Now I remember everything:
  • #8 16928932
    Krzysztof Gorski
    It looks like I don't need a user certificate to send a printout, not an electronic one. But I get a fatal error with DRA documents "The document has unconfirmed payer's details in ZUS", so with advice on the website ZUS I run "Update program components and payer data" I click "Get updates" and the message "Payer data is not current. Do you want to update the data?" and click "Yes" and I have the message "Error: User certificate not found", i.e. the circle closes.
  • #9 16929075
    JacekCz
    Help: 760
    Rate: 1463
    Tell me your business situation, because apart from ZUS, which a small taxpayer (I think) can still submit on paper, electronic VAT comes in, and other obligations.
    The scale of the problem is much greater than clicking something in the program. You do not think about the accounting office? It is impossible to learn this on the electrode.
    In addition to the "qualified certificate", i.e. the card (paid PLN 200-300), it is still and partly can be used in contacts with ZUS (but not a treasury) free so-called "trusted profile", a service without hardware, i.e. PUA. Anyway, another "not very successful" implementation
    Dozens of specific issues can be considered, appearing faster than you can write back. Eg "The document has unconfirmed payer details in the Social Insurance Institution" ... do you have the options switched to "manual mode"? Once, in this mode, the Payer did not require the check in question.
    Maybe still for j.dz.g. after submitting the declaration for the first full month, if there are no changes, so-called "cloning of declarations" occurs ....
  • #10 16931648
    Maciek Sz.12
    Level 4  
    Rate: 14
    Click F8 then Ctrl + O and at the bottom of the first form in the item 'Range of data downloaded during insured files update' change the range from 'Full range' to 'No files update'. There will be no mistakes.
✨ The discussion revolves around issues faced by users of the Płatnik 10.01.001 program in obtaining a user certificate and authenticating data. Users report difficulties in locating the certificate within the program despite following the provided guidelines. Key factors affecting the process include the type of certificate provider, compatibility with Windows versions, and the need for proper software registration. Some users experienced discrepancies between the instructions and the actual program interface, leading to confusion. The necessity of a user certificate for electronic submissions to ZUS is debated, with some users indicating that it may not be required for paper submissions. Additionally, users suggest troubleshooting steps, such as updating program components and adjusting settings to resolve errors related to unconfirmed payer details.
