[Solved] Removing Redirect in AP Mode for SilverCrest SWV 733 A2 & Retain 192.168.1.5 IP Address
alvaro99 6648 5
  • #1 16927170
    alvaro99
    Help: 34
    Rate: 47
    Hello!
    I recently bought a repeater / AP / signal amplifier on sales in a well-known store or if you want a company there SilverCrest SWV 733 A2 .
    I set it to AP mode, everything bangla except that by entering the address 192.168.1.5 in the network, the hardware page opens for a moment, then some alias is made and 192.168.1.5 disappears and https: //repeater.setup/ appears in the address bar and pops up that the page is unavailable ... Initially, the equipment had IP 192.168.10.1 and after typing it, the address bar at https: //repeater.setup/ was displayed and the start page was displayed normally. Now I assigned him an IP hardly from the DHCP server on 192.168.1.5, the alias continues but it cannot find https: //repeater.setup/. How to make the browser not go further but keep the website address after IP 192.168.1.5?
  • #2 16927181
    jimasek
    Help: 3783
    Rate: 2682
    Rather, it would have to be changed in the configuration of the AP / repeater itself and set a static IP address for the LAN. Unfortunately, I was not dealing with this brand.
    Heinzek
    Help: 554
    Rate: 494
    Have you tried to access this equipment from another computer / phone?
    Probably the https: //repeater.setup/ entry was in the DNS cache under the previous IP and therefore the site is down.
    Try typing in cmd on the computer:
    ipconfig / flushdns
    possibly add an entry to the hosts file (C: \ Windows \ System32 \ drivers \ etc \ hosts) add an entry:
    192.168.1.5 repeater.setup
  • #4 16927761
    makosuu
    Help: 369
    Rate: 370
    I have the same device. Sometimes a restart helped when I couldn't enter the panel. Assign it a permanent IP in the panel and turn off DHCP, then you should be able to get in.
  • #5 16928483
    alvaro99
    Help: 34
    Rate: 47
    ipconfig / flushdns
    Thanks a lot, flushdns alone didn't help but hosts + flush entry worked perfectly .
    Restarting both devices (computer / repeater) did not do anything here. I have my IP address permanently set in the "LAN Settings" tab, but I did not give it in "Internet Settings", because the instructions show that these settings apply to the router mode, and I only want the AP.
    In addition, I have secured myself in such a way that the router in Ubiquiti NS M5 automatically assigns me 192.168.1.5 after MAC.
  • #6 17034377
    alvaro99
    Help: 34
    Rate: 47
    Thanks for your help, I'll close the topic.
