Antena 35dBi Dual MIMO 4G LTE TS9 for Huawei B528 T-Mobile: Improve Speed & Coverage?
Bolo731 6216 4
  • #2 16936387
    matek451
    Help: 4356
    Rate: 5816
    Of course it will help but financially the trader offering this electro-waste. You will be the next Janusz in the collection of such smarts. There are thousands of them for your consolation, LTE is a fashionable topic and on Allegro 99% of the equipment is scrap and silencers, not antennas. What is the location, what LTE band are you using in T-mobile, what are the signal parameters and BID CID?
  • #3 16936490
    Bolo731
    Where can I check it because I'm green
  • #4 16936584
    matek451
    Help: 4356
    Rate: 5816
    Enter location, B528 works with http://www.lte-anbieter.info/ltewatch/count_huawei.php?Datei=ltewatch_h in the program you connect to B525, you force the LTE1800, lTE800 and LTE2600 bands in turn will show BTS CID and parameters signal on each. For this speed test. After CID you verify the BTS you are using. B528 also works with the Android application http://www.mediafire.com/file/99t05l2dv6vany8/Huawei_Manager_1.1_PL.apk you install on your phone, connect to B525 for WiFi and log in to APK on 192.168.8.1 and force bands or aggregations of two LTE-A bands and you check as for LTEWatchH.
  • #5 16936821
    Bolo731
    50 ° 35'23.07 "N 23 ° 15'9.65" E
    I can connect only to LTE800
