Mag 250 Decoder No Picture on LG 55SJ800V TV - HDMI Connection Troubleshooting & Solutions
MisYoogi 6429 10
How can I get a Mag 250 decoder to show picture on an LG 55SJ800V TV when HDMI shows the loading screen and then “no signal”?
Turn on the TV’s "HDMI ULTRA HD Deep Color" option for the HDMI input used by the decoder; this made the image appear for the thread author [#16939136] The likely cause is an HDMI/HDCP compatibility mismatch between the older decoder and the newer TV, since the decoder software is from 2015 and no newer version was found [#16938850][#16939136] A reset of both the TV and decoder did not solve it [#16938528] After enabling Deep Color, the picture worked but sound was lost, which matches the warning that this setting can cause loss of image/sound with older decoders [#16939136] If the provider allows it, another fix suggested was replacing the decoder with a different model, but that was said to be unavailable in this case [#16938850][#16939136]
  • #1 16938397
    MisYoogi
    Hello, I just bought a new LG 55SJ800V TV set and I can not connect to the Mag 250 decoder in any way, i.e. after connecting to HDMI 1 and restarting the decoder, loading appears and after a while no signal appears. I would like to point out that the set-top box is working because everything is ok on the old TV, I also called the LG service who said that it was the decoder's fault, while the gentlemen from the cable TV that I have said that it was a TV problem: / butter: /
    Maybe someone of you had a similar problem, thank you in advance for your help, best regards.
  • #2 16938478
    KOCUREK1970
    Help: 3865
    Rate: 5498
    Unplug all the cables from the tv and reset it too (also reset the decoder to be sure).
    MisYoogi wrote:
    also to the LG service which stated that it was the decoder fault, while the gentlemen from the cable TV I had said it was a TV problem: / butter: /
    This is standard text for everyone - each of them took your money and that's it, the problem is yours.
  • #3 16938481
    Pedros050
    Help: 2471
    Rate: 3930
    Hello. Then read the instructions from this LG SMART UHD 4K will this decoder work for you?
  • #4 16938528
    MisYoogi
    I unplugged all cables and from the TV and decoder, restarted it, nothing helps.
    Unfortunately, in the manual attached to the TV, there is no list of decoders with which it works.
  • #5 16938535
    Pedros050
    Help: 2471
    Rate: 3930
    Well, here is probably the problem that this decoder does not work. What type of TV did you have on which the decoder used the old brand?
  • #6 16938569
    MisYoogi
    The old TV model is: LG 42LK450-ZB
  • #7 16938594
    Pedros050
    Help: 2471
    Rate: 3930
    LG 42LK450-ZB ....? But it was just imported from abroad, it is known that it will work but not on SMART UHD.
  • #8 16938630
    MisYoogi
    Yes, this is my 8-year-old TV set from any other country, normally bought in Poland 8 years ago.
    I suspect that the only solution to my problem will be to terminate the contract with the TV provider and sign a new one with another.
  • #9 16938647
    Pedros050
    Help: 2471
    Rate: 3930
    MisYoogi wrote:
    termination of the contract with the television provider and signing a new one with another
    That would be the best solution.
  • #10 16938850
    KOCUREK1970
    Help: 3865
    Rate: 5498
    Or replacing the current operator decoder with a different model.
    The cable decoder probably has the old HDCP, tv a newer version of this protocol and such flowers (at one time Cyfra + also exchanged a lot of its set-top boxes, because they did not work with newer TVs through the newer HDCP version on tv).
  • #11 16939136
    MisYoogi
    Unfortunately, replacing the decoder is not an option, as the cable provider knows, only this decoder model is available. As for HDCP, this could be the problem, I read a little bit and puffed my tongue and it looks like the problem to me. In addition, the decoder software version is from 2015. and I have not found a newer one.
    Added after 35 [minutes]:
    I just noticed that by turning on the "HDMI ULTRA HD Deep Color" function on the HDMI 1 output to which the decoder is connected, the image appeared, unfortunately, as it is in the description of this function, it may lead to loss of image / sound with older versions of the decoder for me it is a lack of sound.
The discussion revolves around troubleshooting an LG 55SJ800V TV that fails to display a picture when connected to a Mag 250 decoder via HDMI. The user reports that the decoder works with an older LG 42LK450-ZB TV but not with the new model. Responses suggest resetting both the TV and decoder, checking compatibility, and considering HDCP protocol issues. A potential solution was found by enabling the "HDMI ULTRA HD Deep Color" feature, which allowed the image to appear, although it may cause sound issues due to compatibility with older decoders. The user contemplates changing their cable provider if the problem persists.
