Iveco Daily Experiencing Body Shake at Speeds Over 100km/h After Part Replacement
Grzegorz weszelaki 11487 10
Why does my Iveco Daily shake in the body and steering wheel above 100 km/h after replacing several parts and balancing the wheels?
This symptom most likely points to a wheel balancing problem [#16957617] Check the tires and wheels for damage as well, because an unbalanced or cracked wheel/tire can cause vibration [#16946199][#16946350] If the problem is still there, inspect the front suspension for play [#19176043] Also check gearbox, engine and cab mounts, propeller shaft crosses, torsion bar bushings, and the steering knuckle pins and steering/reaction rod ends [#19219723]
  • #1 16946155
    Grzegorz weszelaki
    Rate: 8
    Hello, I have a problem. With my Iveco. I replaced the tremors of the whole car and the steering wheel above 100 km. Clutch. Supports. Shaft. And I also challenged the fight itself. The wheels also go on. The same can. Someone. What is it please. For a hint
  • #2 16946199
    szymitsu21
    Help: 343
    Rate: 1300
    Tires? even though a balanced cracked court can cause vibration.
    Braking increases vibrations?
  • #3 16946270
    Grzegorz weszelaki
    Rate: 8
    No. Only. Above. 100 km and how tight. More than 120 Tremor. It ceases
  • #4 16946279
    milejow
    Help: 1563
    Rate: 5149
    Does it tremble more when accelerating, less when you take your foot off the gas?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 16946296
    Grzegorz weszelaki
    Rate: 8
    Does not matter. Is it on the run. Is it easy. Until. Speed won't go down. Below 100 it trembles
  • #6 16946350
    milejow
    Help: 1563
    Rate: 5149
    Replace the wheels if you have where, if you do not - also change :D .
    Działalność własna
  • #7 16946460
    Grzegorz weszelaki
    Rate: 8
    Ok. Thanks
  • #8 16957617
    oress
    This clearly indicates a problem with the wheel balance.
  • #9 19175915
    michale46
    Hey,
    I have a question if the problem was solved because I have the same.
    Maybe you can write what ultimately helped to eliminate the problem.
  • #10 19176043
    kakibara
    Help: 202
    Rate: 1284
    See if you have any slack in the front suspension and the hints above.
  • #11 19219723
    skorp
    IVECO Trucks specialist
    Help: 22
    Rate: 346
    Gearbox cushions, engine cushions or front cab cushions and also propeller shaft crosses.
    Added after 6 [minutes]:
    There are also bushings for torsion bars, if there are in this model, and of course, steering knuckle pins and ends of steering and reaction rods
The discussion revolves around an Iveco Daily experiencing body shake at speeds exceeding 100 km/h after various part replacements, including tremors, clutch supports, and shaft components. Users suggest potential causes such as wheel balance issues, slack in the front suspension, and the condition of gearbox and engine cushions. Recommendations include checking wheel balance, replacing wheels, and inspecting suspension components for wear or damage. The original poster confirms the issue persists only at higher speeds, particularly between 100 km/h and 120 km/h.
