Best 5-Port Switch for Home Use: TP-LINK TL-SF1005D vs. Alternatives for Fast Ethernet Devices
5100 6
  • #1 16950678
  • #3 16950794
    atinus666
    hmmm can tplink?
  • #4 16950846
    LucekB
    Help: 143
    Rate: 137
    up to 100Mb / s
    Everyone will be good
    gigabit for PLN 60 is TL-SG1005D
  • #5 16953987
    resund
    I confirm - at 100, the cheaper the better ... you will not find any difference in individual models
  • #6 17111536
    morling1
    Rate: 49
    There are also others, e.g. D-LINK, TP-LINK has these metal LAN sockets, I do not know if it contributes something and if a shielded cable is sometimes needed?
    What do you say: D-LINK SWITCH GIGABIT 5 PORTS 1000Mbps GO-SW-5G
  • #7 17111669
    jimasek
    Help: 3783
    Rate: 2681
    I have TP-Link TL-SG1005D in my home network and it works fine.
The discussion centers around selecting a suitable 5-port switch for home use, specifically for connecting devices like a Raspberry Pi 3, Philips TV, and DVD player, all of which utilize Fast Ethernet. The TP-LINK TL-SF1005D is mentioned as a potential option, with users confirming its adequacy for 100Mb/s connections. Alternatives such as the D-Link DGS-105 and the TP-LINK TL-SG1005D (which supports Gigabit Ethernet) are also suggested. Overall, the consensus is that for devices limited to Fast Ethernet, a cost-effective switch will suffice, with minimal differences in performance among various models.
