Amica EBI 8562 AA Oven Overheating: Top Panel, Touch Display, Child Protection Failures
Tr1SH 40479 34
Why is the top panel and touch display on my Amica EBI 8562 AA oven overheating during baking, and what should I check before deciding whether to repair or replace it?
The most likely cause is a cooling problem in the upper oven area, so check the top cooling duct, the fan, and any blockage or air leak around that channel, because this model cools the top panel and clock electronics through that path [#16953943][#16974876][#17238357] One user with the same oven said the cooling fan starts when the oven is switched on and stops when the oven is switched off, so the lack of after-run cooling is normal for this model [#16977636] A 20°C temperature difference was described as acceptable, but if the thermostat sticks or the fan is underperforming, the oven can overheat and dump heat into the control panel [#16979920][#17238357] Also check the door seal and that the door closes properly, because a bad seal can add to the heat load near the top panel [#16977636] Cleaning the fan blades and air channel, and looking for a bent cooling tunnel or soot/dust marks where air may leak, were suggested as practical diagnostics before replacing the oven [#16974876][#17238357]
  • #31 17237859
    wojtek__
    Help: 8
    Rate: 150
    nowszy1234567 dnia #30 22 Maj 2018 13:59 wrote:
    the fan works in the top part and on the side of the door I also feel hot air when the oven is hot.
    It is possible that the cooling fan (referring to the supply fan, which in some models is radial in the shape of a cylinder, e.g. Mastercook ovens, and once a propeller with blades, as in the case of the Amica EBI 8562 AA oven described in this thread, depending on model) rotates too slowly because its axle and axle seat are dirty. If this is the case, it is worth lubricating the axle and socket or giving it lubricating oil. It is also important that it is resistant to temperatures up to ~250 ° C.
  • #32 17238357
    suchejro
    Help: 6
    Rate: 54
    There are lubricants resistant to 1000 ° C, but you probably won't find it easily. maybe in automotive up to 300°C it will work and that will be enough. I had such a case in the oven, the upper panel got very hot, it turned out that after years the metal sheet forming the air channel through which the air moves cooling the inside of the oven was slightly bent. Light leaks and that was enough. In addition, a noisy fan, such a roller and not a normal fan, and you know how noise in the fan is, the bearings fail.
    It probably also rotated slower, because when I took it out, I felt a slight resistance by shaking my hand, I put on a new one, sealed it with fireplace paste because that's what I had on hand, although silicones are also up to 250 ° C and more, everything is back to normal. Look if you can't see in places where the metal sheet forming the tunnel ends, whether you can't see such "smoke" black, gray, etc., dust / smoke from the oven after time forms a raid and it's easy to find where the air "leaks".
  • #33 17245755
    nowszy1234567
    Hello, I talked to Amica's service technician and he told me that the thermostat needs to be replaced, but I know that.
    In addition, he said that due to the fact that high temperatures acted on the top panel and thus on the oven clock, the anti-interference filter solder on the clock board had to be corrected. Do you know where such a filter is located and what it looks like? From his report it appeared that the sudden reversing of e.g. the clock, the activation of the oven alarm, etc. could be related to this filter. The filter itself cannot be bought, the whole tile costs PLN 150, so I am looking for different solutions to keep costs down: (the oven model is EBI 8562 AA. The fans work OK :) .
  • #34 17247233
    suchejro
    Help: 6
    Rate: 54
    Remove the plate, take a photo of both sides in good resolution, not a camera with a similar 0.3MPix creation, post it here, someone will know.
The Amica EBI 8562 AA oven is experiencing overheating issues with the top panel, which includes the touch display and child protection features. Users report that the panel becomes excessively hot during operation, leading to erratic touchscreen behavior. Initial troubleshooting suggests checking the thermostat, which may be malfunctioning, as well as the cooling fan, which should operate to dissipate heat. The fan is confirmed to run while the oven is on but stops when the oven is turned off, causing heat to accumulate in the top panel area. Suggestions include cleaning the cooling ducts, lubricating the fan, and potentially replacing the thermostat and thermal switch. Users have also noted that a difference of 20°C in temperature readings may indicate issues with the thermostat's calibration. Some users have experienced similar problems, leading to the conclusion that the cooling system may not be functioning effectively, necessitating further investigation and possible repairs.
TL;DR: 20 °C thermostat drift was recorded, and "These 20 degrees are not the fault of the thermostat itself" [Elektroda, magir, post #16974876]; cleaning the cooling duct/fan and swapping the thermostat (~PLN 50) fixed overheating for several posters [Elektroda, Thread].
Why it matters: Persistent panel heat can destroy the touch-display and cost ≥PLN 150 in parts.
• Replacement main thermostat: PLN 45-60 [Elektroda, magir, post #16953320] • Service call-out only: PLN 200 [Elektroda, Tr1SH, post #16952837] • Full service quote (thermostat + selector): PLN 400 [Elektroda, Tr1SH, post #16974772] • Acceptable temperature hysteresis: ±20 °C [Elektroda, zibi1971, post #16977636] • Fan type: single-speed axial, ~30 W, no speed control [Elektroda, magir, post #16979920]
Why does the Amica EBI 8562 AA top panel overheat after baking?
Heat rises through the front cooling channel; if the fan stops and ducts leak, hot air stalls under the touch display. Dust, bent sheet-metal or a slow fan reduce airflow, so stored heat exits through the panel instead of the grille [Elektroda, magir, post #16978108]
Should the cooling fan keep running after I switch the oven off?
No. In this model the fan is wired with the lamp; it cuts when the selector returns to "0". Leaving the function knob on and thermostat at "0 °C" keeps the fan running for post-bake cooling [Elektroda, magir, post #16978108]
How can I test if the main thermostat is faulty?
Set 150 °C, place an oven thermometer centre-rack, and note cut-off/on points. A 20 °C swing is normal; larger gaps indicate failure. One user saw 225 °C when 180 °C was set [Elektroda, nowszy1234567, post #17234480]
What is the cost and difficulty of replacing the thermostat myself?
The part costs ~PLN 50 and is held by two screws plus capillary clip. Pull the oven, disconnect mains, swap part, refit capillary into the same guide. Time: 30-40 min with basic screwdrivers [Elektroda, Tr1SH, post #16974772]
Where is the thermal cut-out and what does it do?
A white snap-disc switch sits on a rear bracket. If the thermostat sticks, this cut-out kills power to all heaters around 300 °C, preventing pyrolysis-level temperatures [Elektroda, magir, post #16979920]
Could a blocked cooling duct damage the touchscreen?
Yes. Prolonged 100 °C surface temperatures warp the PCB; one forum member reported random beeps and self-activations after such exposure [Elektroda, Tr1SH, post #16952837]
How do I check whether a heater is stuck on due to a faulty selector?
  1. Set light only, 100 °C.
  2. Measure 230 V between selector terminals 1-2, 1-3, 3-4, 5-6.
  3. Voltage on any pair equals an energised heater; replace the selector if voltage appears in the wrong mode [Elektroda, magir, post #16980849]
How can I safely lubricate the cooling fan?
Remove the fan, clean blades, add one drop of 250 °C-rated synthetic oil to each bush. Spin by hand until free, then reinstall. "It certainly won't be worse" [Elektroda, magir, post #16974876]
What temperature swing (hysteresis) is normal for this oven?
A ±20 °C difference between set and actual temperature is within design limits, according to Amica owners and service input [Elektroda, zibi1971, post #16977636]
How do I remove the front knobs without damage?
Wrap the shaft with masking tape, grip the knob sides, and pull straight out—no screws hold it. A user replaced the programmer after knob removal on the twin model [Elektroda, wojtek__, post #17015112]
3-step diagnostic: Is airflow the real issue?
  1. Bake at 200 °C with oven pulled 10 cm out of cabinetry.
  2. Measure grille exhaust; it should feel warm, not scalding.
  3. If panel stays cool, enclosure airflow or door seal—not electronics—is at fault [Elektroda, magir, post #16975202]
