ThinkPad x240 | M.2 42mm SSD Compatibility, SATA Adapter, 6 Gbps Bandwidth Limit
Antek2220 5499 5
  • #1 16954010
    Antek2220
    Hello, I would like to buy a m.2 ssd for my thinkpad, but unfortunately it only supports 42mm disks. If I buy a m.2 to sata adapter (to insert a larger disk), the bandwidth will be limited to 6 Gbps? Will it work on my laptop? Thank you in advance :)
  • #2 16954068
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    Welcome. Indeed, when it comes to m.2 disks, these are only 2242 disks. The laptop also has the ability to mount a standard 2.5 "disk, why use a grommet if you can simply buy an SSD disk in a 2.5" enclosure and mount it? M.2 with a via will not work faster (because it will also be SATA III gen, NVMe disks will not function properly on most of the guides).
  • #3 16954255
    Wojtek(KeFir)
    Help: 678
    Rate: 562
    I don't understand the idea of installing the adapter. There is little space there, how do you want to put your sata controller in there and another sata disk? The more that the m.2 connector already has one sata line from the main board controller.
  • #4 16956279
    Antek2220
    I close the topic, I found a solution.
  • #5 16956357
    dt1
    Help: 7315
    Rate: 8291
    Maybe share the solution with others, maybe it will be useful to someone in the future :)
  • #6 16956400
    Antek2220
    I decided to buy a newer SSD for Sata 3, I close the topic again.
