Best 256GB SSD Options for Lenovo ThinkPad T420: Compatibility with Crucial BX100 SSD
gabdziol 6072 9
Which 256 GB SSD should I buy for a Lenovo ThinkPad T420, and will a Crucial BX100 fit and work in it?
The T420 uses a standard 2.5" SATA drive, so the Crucial BX100 should fit mechanically, but there are forum reports of BIOS detection and OS-installation problems with that model in the T420 [#16511257] A safer choice is a 2.5" SATA SSD such as the GoodRAM Iridium PRO 240GB, which was recommended as a very good drive and should work with the T420 [#16511257][#16511336][#16513088] If you pick another SSD, it is worth checking the exact T420 + drive model combination online before buying, because Lenovo does not publish a clear incompatibility list and returning it may be useful if there are problems [#16511257][#16511336] The Samsung 850 PRO is another option, but it will be much more expensive and you are unlikely to notice a real-world speed difference [#16519201]
  • #1 16511084
    gabdziol
    Rate: 15
    what drive is best to buy for a Lenovo ThinkPad T420 laptop. The size doesn't have to be big, 256gb is enough. I am not sure what model will be suitable. In the second laptop (Samsung) I have Crucial BX100 SSD and unfortunately it does not fit Lenovo.
    Thanks for the help.
  • #2 16511257
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8291
    Welcome. The T420 will fit a 2.5 "SATA drive, so the Crucial BX100 should fit just like any other 2.5" drive. How does this drive not fit you mechanically, or your computer does not want to detect it?
    // edit: Reading the forums T420 and BX100 have problems when it comes to cooperation (that is, it can be mounted, but the BIOS does not detect, or throws an error, or detects, but problems installing the OS). Theoretically, most SATA-2.5 "SSDs should work with this laptop. After choosing, however, it is probably worth entering the phrase T420 + disk model in Google and see if people have problems with this model.
    I recommend GoodRAM Iridium PRO 240GB from good disks.
  • #3 16511319
    gabdziol
    Rate: 15
    I just had a problem with it being dumped in Bios.
    The GoodRam you provided will work ok?
  • #4 16511335
    szkieletor11111
    Help: 63
    Rate: 149
    In terms of size, the housing is a standard must match.
  • #5 16511336
    dt1
    Help: 7315
    Rate: 8291
    It should, it is a very good disk, but officially there is no list of disks with which the Lenovo T420 has problems, so just in case it is worth taking from a store that will not make problems with regulatory return.
  • #7 16513491
    gabdziol
    Rate: 15
    Thanks for the link. Hopes that you won't have problems with the Lenovo thinkpad t420.
  • #8 16514780
    Brozerihno
    Help: 28
    Rate: 44
    There should not be any problems
  • #9 16518883
    gabdziol
    Rate: 15
    I am just thinking about the above or Samsung 850 PRO.
  • #10 16519201
    dt1
    Help: 7315
    Rate: 8291
    Samsung will come out much more expensive, and you will not notice the difference in speed in real use.
The Lenovo ThinkPad T420 is compatible with 2.5" SATA SSDs, including the Crucial BX100, although users have reported issues with BIOS detection and installation. Alternatives such as the GoodRAM Iridium PRO 240GB are recommended, noted for their reliability and warranty. The Samsung 850 PRO is also considered, but it is more expensive with negligible performance differences in practical use. It is advisable to check compatibility by searching for specific SSD models in relation to the T420 to avoid potential issues.
