7060b 2din radio and camcorder - The camera does not turn on when the radio is o
ladril 11673 4
  • #1 16966699
    ladril
    I have this problem, I connected the 2din model 7060b radio with the reversing camera,
    The camera is turned on only when connected to videoinput and manually switched to AUX or DVR,
    I would like it to turn on when you engage reverse gear.
    I would like to add that I connected the power supply of the camera to the cables supplying the reverse gear bulb, so after switching on the reverse camera turns on, but only in the mentioned modes on the radio.
    Do you have any ideas how to set it to turn on while playing a radio?
    I made a movie:
    https://youtu.be/oGUKUAmUe-s
  • #2 16966730
    bubu1769
    Help: 1177
    Rate: 2374
    Did you connect the pink wire in the ankle under the signal from the reverse?
  • #3 16967430
    ladril
    There are two wires from the camera, one black the other is red, and I had two at the exit from the bulb, so I plugged in. The camera turns on and works after the reverse gear is in progress. But not in the mode in which I expected it
  • #4 16967555
    bubu1769
    Help: 1177
    Rate: 2374
    Pink wire in the cube from the radio.
  • #5 16968168
    ladril
    Thanks !! I will check today and let me know :)
