A GET request using esp8266 returns HTTP/1.1 301 Moved Permanently
Testownik 804 0
  • #1 16970676
    Testownik
    When pasting programme code, please use the SYNTAX tag. The syntax is then coloured and the code is easy to analyse, plus the posts are short. Instruction: https://www.elektroda.pl/rtvforum/topic3300722.html
    However, even if you get it right you will get it:
    Code: HTML, XML
    Simply put, onet works over https (https://www.onet.pl).
