Retrieving values from a page using the ESP8266 01 module - Arduino code
swiderEK1 1002 5
  • SoftwareSerial on pins 0/1 conflicts with USB serial
    #1 19626035
    swiderEK1
    Rate: 17
    Help because I'm stuck, I want to retrieve a certain value from a page with the ESP8266 01 module with the following code:
    Code: C / C++
    this code gives "none"
  • #2 19627456
  • Use serial buffering and hardware UART at 115200
    #3 19641133
    kaczakat
    Help: 317
    Rate: 231
    See the Arduino SerialEvent example, it takes a while to send a character, with 9600 it's even a very long time, during this time the Arduino does thousands of checks if there is a character in the buffer and tries to print this text, it probably gets clogged up after a while. You have to collect the letters one by one into your buffer, make a line of text out of them (and it's good to send it in such a way that the message ends with a NL/CR character, which gives you information to do something with it now). And of course as khoam mentioned use hardware, then you can also set it to 115200 and it will be much faster.
  • #4 19646266
    gbksiazczak
    Help: 166
    Rate: 326
    Why is the same sequence of if statements repeated 2 times in the loop?
  • #5 19646275
  • #6 19646281
    gbksiazczak
    Help: 166
    Rate: 326
    Can availability (available?) be in only one case? Do you have to check both?
