Choosing the Right Buderus Condensing Furnace Power for a 118m2 House with Underfloor Heating
Bajarka79 4698 12
What boiler power should I choose for a 118 m² newly built house with underfloor heating downstairs and radiators upstairs, and do I need a separate DHW storage tank?
A 14.9 kW boiler is not automatically too small for a 118 m² new build, but the thread emphasizes checking the boiler’s minimum modulation and DHW demand instead of just accepting the old 24 kW project value; one reply said about 18 kW should be OK, and another warned that the minimum output matters more than the maximum [#16973898] [#16974141] [#16974575] If you keep a mixed system with underfloor heating downstairs and radiators upstairs, use a separate mixed circuit with a mixing valve, actuator, and separate heating curves/controls for the two zones, rather than a floor manifold with a built-in thermostatic pump/mixing set [#16974800] Another opinion was that mixed floor/radiator installations are less economical and that underfloor heating everywhere is the better match for a condensing boiler [#16975014] For domestic hot water, the advice was to size the storage tank first and then choose the boiler accordingly, so the need for a separate reserve depends on the DHW solution rather than the heating load alone [#16975014] [#16974788]
  • #1 16973595
    Bajarka79
    I am asking for advice on selecting the power of a condensing furnace. I had 24kW in the project, but recently I was offered a 14.9kW furnace.
    Newly built house of 118m2.
    The stove is to be in the bathroom with a tray (separate). The sink in the kitchen is about 2.5 meters from the stove. Above the bathroom is the upstairs bathroom.
    The house has 1 bath, 1 shower, 2 toilets, 2 sinks, 1 sink, 40cm dishwasher.
    Additionally, there will be a free-standing stove in the living room.
    Ground floor: underfloor heating + towel rail radiator in the bathroom
    floor: radiators in 3 bedrooms, small hall, ladder in the bathroom, but underfloor heating in the bathroom.
  • #2 16973607
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, I personally recommend Dietrich. Affordable and of very good quality.
  • #3 16973747
    Bajarka79
    Only about what power? 24kW or less?
    daro31ie
    Help: 366
    Rate: 650
    Buddy, power And you will also limit it programmatically. In your case, 18kW should be OK.
  • #5 16973954
    Bajarka79
    Thank you for your answer.
  • #6 16974138
    kasprzyk
    Electrician specialist
    Help: 354
    Rate: 671
    Why 18kW exactly, how do you know it?
    Friend? Bajarka79 why floor heating mixed with radiators in a newly built house (I do not mean ladders in the bathrooms)
  • #7 16974141
    BUCKS
    Help: 536
    Rate: 1087
    For heating purposes, it is the minimum power that matters, not the maximum power.
    Supposedly, the standard for single-family houses from 2017 is 95kWh / m2 per year.
    95 * 118 = 11210kWh per year for the whole thing, so I will go for heating from this, I shoot about 70%, which is approx. 7850 kWh.
    With so little energy demand, the minimum power is very important.
    Although here it is a floor heating + radiators, may it not work out for the investor, if he has problems with tuning the whole.
    I am not a professional, but I can barely see the heating of radiators when the floor heating is already warming up, without an appropriate heat buffer it can be poor.
    It is worth asking and asking specialists for advice before buying and installing.
  • #8 16974390
    Bajarka79
    That's what you advised me from the installation. It was about the comfort of sleeping in the bedrooms, because apparently the air is bad at the floor. I also know this from people who only have a floor.
    It is known that a mixer will be installed.
  • #9 16974575
    kasprzyk
    Help: 354
    Rate: 671
    If the same gentleman advised you a 14.9kW boiler, I suggest you change the installer as soon as possible and use the feed mixer.
    Ask this "specialist" how the air circulates at a high-temperature radiator and, as with a low-parametric floor heating, ask him also when the efficiency of the condensing boiler is the highest, unless you do not care about the economic operation of the entire system.
    If you do not have a bare brick house built, let your pseudo installer choose the boiler power in terms of the possibility of preparing DHW and not the maximum CH
    BUCKS
    Help: 536
    Rate: 1087
    kasprzyk wrote:
    If the same gentleman advised you a 14.9kW boiler, I suggest you change the installer as soon as possible [...]
    Only in my opinion, such posts do not help the author, because they do not explain anything.
    Although I have licked the subject of heating myself, I do not see a problem in heating a domestic hot water tank with a capacity of e.g. 150 l with a gas boiler with a power in the range of 1.9-12kW, since electric boilers usually have about 2kW.
    I am aware that the planned consumption of domestic hot water will affect the selection of a tank with an appropriate capacity and a boiler with appropriate power, so that the time of preparing domestic hot water will not be too long.
    But I cannot make calculations myself to match everything correctly and choose the most optimal option, but I do not understand why you disqualify the installer who proposed the 14.9kW model in advance.
    When choosing a gas boiler, we will always face the dilemma of what to choose:
    - low minimum boiler power of e.g. 1.9kW for central heating needs, at the expense of lower maximum power for domestic hot water,
    - higher maximum power of the boiler for domestic hot water needs, at the expense of higher minimum power for the needs of central heating, exceeding the actual heat demand
    I have doubts which solution will be definitely better, because I have not had any practical contact with any of these solutions in a building insulated according to the latest standards with underfloor and radiator heating.
    ls_77
    Help: 500
    Rate: 947
    Just remember that if you have an underfloor heating system downstairs and radiators on the top, then this "mixer" is preferably a separate heating circuit on the mixing valve and an actuator controlled by the boiler automation with a separate heating curve for radiators and a separate heating system, and the best remote control with readout temperature at the top separately and at the bottom separately. Do not be persuaded to buy a floor heating manifold with a built-in thermostatic pumping and mixing system, because then there will only be questions about how to set it right, because it's either too hot or too cold.
  • #12 16974916
    Bajarka79
    Thanks for the answers. Now I know at least what to ask and what else to pay attention to before buying and installing.
    Added after 24 [minutes]:
    Would someone be tempted to give a specific proposal of a condensing furnace with all the accessories to my home?
    Information about the house is in an earlier post.
    The house will be insulated with 20 cm polystyrene.
    BATHROOMS are one above the other and the sink is about 2 meters from the stove. The rest is unchanged.
    Maybe there are more heaters on the floor?
    One more thing: could it do without a separate water reserve?
    kasprzyk
    Help: 354
    Rate: 671
    Pay attention to the nature of the questions asked, the person is asking as a layman, and in a moment he uses the phrase " you know that a mixer will be installed "
    So let the questioner determine whether she is interested in possible correct solutions, whether she has an installer, brother-in-law / uncle Kazio who, as a handyman, has a plan and waits only for the approval of others, and considers any words of criticism to be an attack on his wonderful plans.
    Coming back to the essence of col. Bajarka79, please read a little here about the selection of the tray: https://www.budkuje.pl/wiadomosc/zasobnik-cwu-jak-wybrac-jaki-najlepszy/1192/ (the first result found in google, you can look for this more) if it is decided on the size of the heater, you can select the heating boiler.
    I would not worry about the power reserve for CO here - only very important - with a condensing boiler, floor heating throughout the apartment - what advantages? please read e.g. here: http://www.e-instalacje.pl/a/podlogowka-zalety-i-wady-3932.html
    If you have a lot of money - please make a mixed installation - floor heating and radiators everywhere (I have met one of them), the client explained by the fact that it is possible to regulate the daily temperature in the rooms - in practice, the cooling of currently well-insulated flats is so slow that such regulation is not right being. If someone is too warm in the bedroom - it permanently reduces the daily temperature.
    Condensing boiler, heat pump - only underfloor heating !!! Mixed installations - throwing money down the drain, additional costs of separate heating circuits, uneconomic boiler operation, cluttering the apartment with radiators, please think carefully, and stories about bad air are just nonsense, myths of grandma and grandparents who once refused to use plaster walls, because they are smooth and don't "breathe" ;)
The discussion revolves around selecting the appropriate power for a condensing furnace for a newly built 118m2 house with underfloor heating and radiators. The user initially considered a 24kW furnace but was offered a 14.9kW model. Responses suggest that an 18kW furnace may be suitable, emphasizing the importance of minimum power for energy efficiency. Concerns were raised about the compatibility of underfloor heating with radiators and the need for a mixing valve to optimize temperature control. The discussion also highlights the significance of consulting professionals for proper installation and system tuning, as well as considerations for domestic hot water heating. Recommendations include ensuring the heating system is designed to accommodate both underfloor heating and radiators effectively.
TL;DR: For a 118 m² home, estimate ~11,210 kWh/yr (95 kWh/m²·yr). “For heating purposes, it is the minimum power that matters.” Choose a condensing boiler with very low minimum output, then size maximum output for hot water comfort. [Elektroda, BUCKS, post #16974141]
Why it matters: Right-sizing avoids cycling, cuts bills, and keeps underfloor heating and radiators stable for everyday use.
Quick-Facts
What boiler power fits a 118 m² house with UFH downstairs and radiators upstairs?
Size for low minimum output first to match the small space‑heating load and avoid cycling. Then ensure maximum output meets your domestic hot water target. “For heating purposes, it is the minimum power that matters.” [Elektroda, BUCKS, post #16974141]
Is 24 kW overkill for heating this house?
For space heating, yes—the annual demand suggests modest peak needs. High maximum power mainly helps instant hot water recovery, not steady heating. Consider models with low minimum power and only as much maximum as your DHW pattern requires. [Elektroda, BUCKS, post #16974141]
Could a 14.9 kW Buderus work here?
It can, if its minimum modulation suits UFH and its maximum output covers your DHW plan. Choose power “in terms of the possibility of preparing DHW,” not just CO peak. [Elektroda, kasprzyk, post #16974575]
Why is minimum modulation more important than maximum power?
Low minimum power lets the boiler run steadily with UFH’s low temperatures. That reduces cycling, noise, and wear, and improves condensing efficiency. “For heating purposes, it is the minimum power that matters.” [Elektroda, BUCKS, post #16974141]
How should I design a mixed UFH + radiator system correctly?
Create two heating circuits: a mixing valve with actuator for UFH and a higher‑temperature circuit for radiators. Control each with its own heating curve and separate room feedback upstairs and downstairs. [Elektroda, ls_77, post #16974800]
Are thermostatic pump-mixing manifolds for UFH a good idea?
Avoid them as the sole control. Users report “either too hot or too cold.” Use a boiler‑controlled mixing valve with an actuator and separate curve instead. [Elektroda, ls_77, post #16974800]
Do I need a hot-water tank, or can I go tankless?
A cylinder improves multi‑tap comfort and lets you keep a low minimum heating output. Even a 1.9–12 kW boiler can heat a 150 L tank; tankless needs higher peak power and fast flow control. [Elektroda, BUCKS, post #16974788]
Is full underfloor heating better than mixed emitters for a condensing boiler?
Yes. Underfloor throughout supports low temperatures and higher condensing efficiency. Mixed systems add cost, extra circuits, and can reduce economy if misconfigured. [Elektroda, kasprzyk, post #16975014]
Does underfloor heating cause “bad air” in bedrooms?
No. That’s a myth. With correct design, UFH is comfortable and efficient, and avoids the high‑temperature convection of radiators. [Elektroda, kasprzyk, post #16975014]
Can I limit boiler output via software if I buy a higher‑power unit?
Yes. You can programmatically limit output. One responder suggested ~18 kW and noted output can be capped in settings. [Elektroda, daro31ie, post #16973898]
Which boiler brands were recommended in the thread?
De Dietrich was recommended as affordable and of good quality. Consider models with wide modulation for UFH and DHW needs. [Elektroda, daro31ie, post #16973607]
How big should my DHW tank be for two bathrooms and a kitchen?
A 150 L class tank is a practical start for two bathrooms, supporting showers and typical draws. Pair it with a boiler whose maximum output matches your desired reheat time. [Elektroda, BUCKS, post #16974788]
Do mixed systems need a buffer tank?
They can. Radiators may ask for heat before UFH warms up. A small buffer helps stabilize flow and temperatures when tuning mixed emitters. [Elektroda, BUCKS, post #16974141]
How do I commission two heating curves without comfort swings?
  1. Create separate UFH and radiator circuits with a motorized mixing valve for UFH.
  2. Assign distinct heating curves and room feedback upstairs and downstairs.
  3. Trim curves over a few days to stop overshoot or lag. [Elektroda, ls_77, post #16974800]
What information about the house matters for boiler choice?
List floor area (118 m²), emitters (UFH downstairs, radiators upstairs), bathroom count, and hot‑water distances. Short DHW runs and stacked bathrooms improve comfort and reduce peak demand. [Elektroda, Bajarka79, post #16973595]
Can I add a wood stove and still keep the boiler happy?
Yes. A freestanding stove can cover part of the load. Ensure controls and any buffer handle intermittent stove heat to prevent boiler short cycling when rooms warm. [Elektroda, BUCKS, post #16974141]
