[Solved] - Missing Polsat Cyfrowy Channels on 3rd Multiroom Decoder: Signal Strength & Converter Issues
Beniczek78 4923 8
  • #1 16976315
    Beniczek78
    I have a rather strange problem. Tv Polsat digital + 3 multiroom. Everything is fine on the main decoder and 2 multirooms, on the third one on several channels there is information about the lack of signal. There is a similar strength and quality of 75/80 on each decoder. The converter has eight outputs. I tried to connect the cable to others. Nothing helps. What may be the problem. Please help.
  • #2 16976454
  • #3 16976618
    andpol 33
    Help: 507
    Rate: 1137
    Swap decoders. You will know if the decoder is functional.
  • #4 16976938
    Beniczek78
    And more specifically ??
  • #5 16976995
    maksar
    Help: 177
    Rate: 1029
    Call a repairman.
  • #6 16977102
  • #7 16977652
    KOCUREK1970
    Help: 3830
    Rate: 5422
    Well, there is still a cable to be checked.
  • #8 16977677
    andpol 33
    Help: 507
    Rate: 1137
    But what you do not understand? Take that busted decoder and plug it where everything works fine. If the latter does not work properly either, you have a decoder to replace. If everything will be ok, it means that you have a problem with installing the converter-defective decoder line.
  • #9 18004411
    Beniczek78
    The problem was solved by a good quality converter.
✨ The discussion revolves around a user experiencing signal issues with the third multiroom decoder of their Polsat Cyfrowy setup, while the main decoder and two other multirooms function correctly. Despite similar signal strength and quality readings of 75/80 across all decoders, the third unit reports a lack of signal on several channels. Suggestions from other users include checking the installation, swapping decoders to test functionality, and inspecting the cables. Ultimately, the user resolved the issue by replacing the converter with a higher quality model.
