[Solved] Washing machine Samsung WF0500NUW - The drum does not spin and the rest works
Xxxmateuszxxx51 13389 5
  • #1 16976641
    Xxxmateuszxxx51
    Hello I have a question. What could be the reason that the drum does not spin in the washing machine? The belt is stretched, moving your hand normally turns. The washing machine normally starts working, takes in water and does not want to spin at all. I pulled out the brushes, they seemed good, screwed them back on my eye and the drum started spinning. Heals when the next day I wanted to put the laundry the drum did not move. Please help.
  • #2 16976764
    Boryc2014
    Help: 21
    Rate: 90
    At the beginning I would check the connection of all the wires or one that does not touch somewhere. He checked all of them for damage and finally replaced the brushes with new ones. If this does not help or there is no damage to the wires, then the problem may be in the programmer. Then you need to give a washing machine repair specialist, and is this a new washing machine or a used one, and how old is it?
  • #3 16977175
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    What length are they?
  • #4 16977298
    Xxxmateuszxxx51
    About 2.5cm and the washing machine is about 3 years old
  • #5 16981777
    Boryc2014
    Help: 21
    Rate: 90
    Do as I wrote above and write if you have established something
  • #6 18775334
    Xxxmateuszxxx51
    Replacing the brushes helped. Visually they looked good but something was wrong with them.
