Comparing Huawei B310 and Huawei E5785 (Cat. 6) Routers: Speed and Range Parameters
rybka2364 10581 4
  • #1 16982284
    rybka2364
    Rate: 20
    Hi, I have a question, I am prolonging the internet contract and I wonder what router will be better for mostly home use. I hesitate between the Huawei B310 and the Huawei E5785 (Cat. 6) .... I care about the parameters, the possibilities were maximally the best, i.e. the speed and range of the signal.
  • #2 16982650
    makosuu
    Help: 369
    Rate: 370
    E5785 can achieve higher speeds on LTE but lacks LAN ports, has smaller antenna connectors, is not very good as a stationary router. The B310 has a slower modem without aggregation but has a LAN, turns on after connecting to power and is generally designed for 24/7 stationary work with power supply. By. B310 is better for me if it's a stationary device. Where's your choice?
  • #3 16982803
    matek451
    Help: 4352
    Rate: 5808
    And why extend the Play subscription and pay 59.99 PLN / month as a minimum of 100GB LTE in Play without a contract you can have for 5/15 PLN / month? The contract for two years, in addition weak. The equipment is better to buy for yourself, the B310 is a weak router for the LTE offer in Play. Worth 200 PLN. It does not support LTE bandwidth aggregation. to play the minimum router with aggregation of 2 bands LTE or B525 and optimally B715. You can buy a B525 for around PLN 350 just like the E5186.
  • #4 16983551
    makosuu
    Help: 369
    Rate: 370
    Not everyone knows, not everyone has the desire to combine to get the right tariff from RWK, etc. It is easier for the ordinary user to take a subscription, the router will get and most home users probably never even this funnel received 100GB.
  • #5 16985146
    rybka2364
    Rate: 20
    Thanks for the answers, I think that this time I will decide on stationary, I will see how it will perform, and in case of performance problems or how, I think I will use the previous router (Huawei E5377) .... and draw conclusions for the future.
