Switching Between Main and Sub Stream in FreeIP Application: Step-by-Step Guide
jeremiw1 4455 4
  • #1 16984340
    jeremiw1
    Help: 24
    Rate: 19
    Gentlemen, I have a FreeIP application on my phone, the recorder preview via P2P works without a problem, but I don't know how to switch between the main stream and the stream.
    From what I can see at the start, the main stream fires, how to change it?
  • #2 16984351
    jpl
    Help: 240
    Rate: 223
    Read the instructions, call the seller who sold you the recorder.
    Answers to such questions should be provided by the company that sells this equipment.
    The electrode is not a free helpdesk
  • #3 16984390
    sneer
    And it was enough to write that it is a matter to set / check / anything on the recorder side, not the FreeIP application :-(
  • #4 16984394
    jeremiw1
    Help: 24
    Rate: 19
    There are two streams set in the recorder, which can be easily viewed online through the VMS program, so the recorder is fine.
    Unfortunately, I don't know how to set it up in the app.
    It is difficult, I will call the hotline.
  • #5 16984621
    jpl
    Help: 240
    Rate: 223
    In most of the WELL-written applications, there is an option to change the display quality = which is equivalent to switching the preview between streams (main - better, auxiliary - worse).
    Really, for the person selling this product, it's about 2 minutes to go ... let's not be so lazy again. Let's demand something from sellers.
