Differences Between Digitizer and LCD Display in LG Spirit: Cost and Functionality
tomek13710 38649 9
What is the difference between the digitizer and the full LCD display in an LG Spirit, and do I need to replace only the digitizer or the whole screen after a drop?
Digitizer is the touch layer, while the display is the part that shows the image [#16986270][#16986370] If touch still works, the digitizer is probably still responding, but that does not mean the display or the glass is not damaged [#16986370][#16986441] On some phones the touch layer can be replaced separately, but removing a damaged LCD/digitizer assembly at home can be difficult [#16986274] If the screen is cracked badly or you have a hole/spidering, it may be more sensible to replace the whole display assembly rather than only the touch layer [#16986441] Because the drop was serious, it is also worth having the phone checked by a service before buying parts [#16986441][#16987282]
  • #1 16986179
    tomek13710
    My problem is that my phone has dropped (lg spirit), the screen went down quite well because in the place where there was the LG logo there is a hole that you can see the inside of the phone but the touch works. My question is how the digitizer differs from the entire LCD display because I went on the Allegro and I do not know what the difference is because the digitizer costs PLN 30 and the display PLN 100?
  • #3 16986274
    gonzalo
    Help: 194
    Rate: 157
    Digitizer is a touch screen and the display is known. Rather, in home conditions you will have a problem with removing the damaged LCD digitizer without damaging it.
  • #4 16986342
    tomek13710
    I understand, that is, if the phone reacts, the touch works, then you can replace the digitizer itself, there is no need for the whole screen?
  • #5 16986370
    michalek1988
    Help: 68
    Rate: 181
    If it responds to touch, why would you like to exchange it? Digitizer is a transparent screen overlay (but not tempered glass, or any other protection!), A display screen that shows you what you do on your phone.
  • #6 16986406
    tomek13710
    Because once it falls again it can stop working completely
  • #7 16986441
    michalek1988
    Help: 68
    Rate: 181
    The display may also stop working and the touch will remain operational. The one you have now is cracked or otherwise suspicious / damaged? If you do not like its condition, then replace it with the display. It would be good to check other functions of the phone so that it does not turn out that you buy and you can not catch the range. If you feel strong enough to make a repair and want to risk buying these parts then please. But as you mentioned, the fall was quite serious, maybe it would be cheaper to order someone to check your phone and just make a decision to make a repair?
  • #8 16986490
    tomek13710
    It is dirty so that below the screen is about 2 cm free only logo and there is a hole there that I see what is inside the phone and a spider yet
  • #9 16987282
    michalek1988
    Help: 68
    Rate: 181
    Are you expecting someone to tell you what to replace without seeing and unable to check the phone? Differences between one and the other already a few people have explained to you, if despite all this is beyond you, then only the service saves you. If you need other help, then give details, ask questions.
  • #10 16988525
    tomek13710
    You're right to give it to the site better. Thanks for the help.
The discussion revolves around the differences between a digitizer and an LCD display for the LG Spirit after the user's phone suffered physical damage. The digitizer is identified as the touch-sensitive layer that registers touch input, while the LCD display is the component that visually presents the content. Users suggest that if the touch functionality is still operational, it may be possible to replace just the digitizer instead of the entire display, which is more expensive. However, concerns are raised about the potential for further damage and the importance of assessing the overall condition of the phone before proceeding with repairs. It is recommended to consult a professional for a thorough evaluation.
