Kraft & Dele KD136 Genset 7HP 3000/2800W: Oil Indicator Light On - Normal or Problem?
domelk 9903 11
Why does the oil indicator light stay on continuously after starting a Kraft & Dele KD136 generator, and is that normal after filling with oil?
The KD136’s oil light may be wired so that it lights when the oil system is OK, not when oil is low, and the service answer also said the KD136 differs from the KD138 in this respect [#16993956] If the oil level is correct but the light still stays on, check the oil level sensor and its wiring: disconnect the sensor lead to see whether the lamp changes, or touch the sensor lead to ground to test whether the engine shuts off [#16993718][#16993998][#16994203] In this thread, grounding the sensor made the unit switch off, which points to a low-oil sensor circuit that shorts to ground when oil is missing and is open when oil is present [#16994044][#16994203] The original poster later reported that after several starts and an oil change, the diode went out and stayed off, so the issue resolved itself [#17474772]
  • Clarifying oil indicator behavior on KD136 genset
    #1 16990182
    domelk
    Rate: 28
    Hello, not long ago I purchased the unit as in the title and after starting it, the oil indicator light is on all the time.
    My question is whether in this model, after flooding with oil, the light should be on, and if there is no oil, it will go out because nothing is written in the manual.
    For the sake of rectification, I will write that it is the kd136 7hp 3000 / 2800W model
    https://kraftdele.info/agregaty-jednofazowe/529-agregat-3000w-12230v-kd136.html
  • #2 16990421
    barton21
    Help: 79
    Rate: 193
    Was the unit new or used? From what I know, the light should come on when there is little oil.
  • #3 16990518
    domelk
    Rate: 28
    Brand new and the light is on all the time after firing
  • #4 16993718
    Staszek49
    Help: 228
    Rate: 1140
    Oil level sensor defective (blocked). For a test, disconnect the sensor connection (it should be with a clip) and if the light goes out, look for faults in this circuit.
    On aggregates with such a sensor but without an indicator light, low oil level turns the engine ignition off.
  • #5 16993725
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    The oil is OK, I suppose? Given the possible damage to the aggregate, he suggests immediate sensor replacement! There is (as in Chinese engines) the possibility of a design error - e.g. no plug in the oil channel or the like.
  • #6 16993834
    barton21
    Help: 79
    Rate: 193
    If the oil level is ok and the indicator light is on, I suggest that you return the generator to the store where it was purchased.
  • #7 16993956
    domelk
    Rate: 28
    I called the kraftdele service and got the answer that in the kd136 models the oil indicator works the other way around, i.e. it lights up if everything is ok, and in kd138 (on wheels) it is corrected and it lights up when there is no oil. However, something does not suit me. On Monday I will call again and go on a different barrel.
    I don't know what to do with it now.
    PS. I unplugged the oil sensor with a clip and it still lights and the unit works.
  • #8 16993998
    barton21
    Help: 79
    Rate: 193
    And touch the insert from the oil sensor to the mass and see if the light goes out
  • #9 16994044
    domelk
    Rate: 28
    After touching the ground, the unit turns off.
  • #10 16994203
    barton21
    Help: 79
    Rate: 193
    So the matter is now clear. When there is no oil, the sensor shortens to ground and turns off the unit. When there is oil, the sensor is open.
  • #11 17474101
    Kriss2275
    Hello. How did you solve the problem with the oil indicator light diode burning ??? ????
  • #12 17474772
    domelk
    Rate: 28
    Hello, the problem with the lit diode solved itself. After several starts of the unit, I changed the oil and now when I start it the diode is off.
The discussion revolves around the Kraft & Dele KD136 generator, where the oil indicator light remains illuminated after starting the unit. Users inquire whether this is normal or indicative of a problem. Initial responses suggest that the light typically indicates low oil levels, but the owner clarifies that the unit is new and the light stays on continuously. Further investigation reveals that the oil level sensor may be defective, and disconnecting it does not resolve the issue. A service representative informs the owner that the KD136 model's oil indicator functions oppositely compared to other models, lighting up when oil is present. Ultimately, the owner resolves the issue by changing the oil, which turns off the indicator light after several starts.
TL;DR: KD136 uses 2‑state oil-sensor logic—“When there is no oil, the sensor shortens to ground and turns off the unit.” [Elektroda, barton21, post #16994203]
Why it matters: This FAQ helps KD136 owners troubleshoot an always‑on oil light and avoid engine damage or needless returns.
Why is the oil indicator on my KD136 always on?
One owner reported the KD136 lamp stays on despite correct oil. Service suggested KD136’s lamp can indicate “OK,” unlike KD138. This created confusion. The same owner later saw the lamp go off after several starts and the first oil change. [Elektroda, domelk, post #16993956]
Does the KD136 shut down on low oil?
Yes. The circuit shorts to ground on low oil and cuts ignition. With oil present, the sensor remains open. As one expert put it, “When there is no oil, the sensor shortens to ground and turns off the unit.” [Elektroda, barton21, post #16994203]
How can I test the oil level sensor safely?
  1. Locate the oil‑sensor lead and ensure the unit runs at idle.
  2. Briefly touch the sensor lead to engine ground using an insulated tool.
  3. Confirm the engine stops instantly; release immediately. This verifies the shutdown circuit. [Elektroda, domelk, post #16994044]
Could the oil sensor be defective from new?
Yes. A blocked or defective sensor can misreport oil status. Disconnect the sensor at its clip to isolate the circuit. If the lamp behavior changes, the fault is in that path. Replace the sensor if confirmed defective. [Elektroda, Staszek49, post #16993718]
Should I replace the oil sensor right away if I suspect a fault?
An expert recommended immediate sensor replacement to prevent engine damage. He also noted possible design errors in some engines, like missing oil‑channel plugs, which can mislead indicators. [Elektroda, Krzysztof Kamienski, post #16993725]
Should I return the generator if oil is OK but the lamp stays on?
Yes, returning to the retailer was advised when the oil level was correct and the indicator stayed illuminated. This avoids warranty issues and confirms whether the unit is within spec. [Elektroda, barton21, post #16993834]
What ultimately resolved the always‑on oil lamp for the original poster?
The owner reported the lamp turned off after several starts and the first oil change. That is one documented case showing normal behavior resumed post break‑in and fresh oil. [Elektroda, domelk, post #17474772]
Will disconnecting the oil sensor turn the lamp off?
Not necessarily. The owner unplugged the sensor and the lamp still lit while the unit continued to run. This suggests the lamp circuit can be independent or latched. [Elektroda, domelk, post #16993956]
What exactly does the oil sensor circuit do on this genset?
It acts as a two‑state switch: open with adequate oil, short‑to‑ground with low oil. The ground state disables ignition, stopping the engine to prevent damage. “Open with oil; short without oil.” [Elektroda, barton21, post #16994203]
Is there a model difference between KD136 and KD138 oil lamps?
Yes, according to service feedback relayed in the thread. KD136 was said to light when all is OK, while KD138 lights on low oil. Treat this as model‑specific indicator logic. [Elektroda, domelk, post #16993956]
What’s a quick diagnostic if the lamp stays on but oil is correct?
Perform the ground test. Briefly touch the sensor lead to ground while running. If the engine stops, the shutdown path works, and the issue is likely the indicator logic or sensor state. [Elektroda, domelk, post #16994044]
Can a faulty oil sensor prevent starting even with oil present?
Yes. If the sensor falsely shorts to ground, the ignition is cut and starting is blocked. That’s a designed failure mode to protect the engine from damage. [Elektroda, Staszek49, post #16993718]
Are there signs of a broader design issue to watch for?
One expert mentioned potential design errors in similar engines, such as missing plugs in oil passages. If symptoms persist after testing, escalate to warranty service. [Elektroda, Krzysztof Kamienski, post #16993725]
What are the basic specs of the generator discussed here?
The thread centers on the Kraft & Dele KD136 genset, rated 7 HP with 3000/2800 W output. This helps you match procedures to the correct model class. [Elektroda, domelk, post #16990182]
Does a single owner report support the ground‑shutdown behavior?
Yes. The owner confirmed the engine shut down immediately when the sensor lead touched ground during testing. That validates the circuit. [Elektroda, domelk, post #16994044]
What’s the simplest path to resolution before returning the unit?
Check oil level, run the ground‑test, then perform an early oil change. One owner saw the lamp clear after these steps. If unresolved, seek replacement. [Elektroda, domelk, post #17474772]
