[Other] Microsoft Windows 1 Key 2 Systems | Installing Windows 10 using Windows 7 OEM Key - Legal?
Tomasz4292 4086 10
Can I legally install Windows 10 on another computer using a Windows 7 OEM key?
No, a Windows 7 OEM license is tied to the original machine it was purchased with and first activated on, so installing Windows 10 on another computer with that key does not comply with the license [#16997945] You need to buy a new key for the other PC; there is no option to transfer the old OEM key as-is [#16992244] The same applies to a Windows 10 OEM key from a laptop: using it on a different computer is not legal under the OEM terms [#16998154]
  • #1 16992131
    Tomasz4292
    I have a question, I want to install Windows 10 from a windows 7 OEM key. So will it be illegal to install Windows 10 with original key from 7?
  • #3 16992203
    Tomasz4292
    I meant to install the system on another computer
  • #4 16992244
    Pedros050
    Help: 2471
    Rate: 3926
    And there is no such option, win10 will not be up to date. You must purchase a new key.
  • #5 16996543
    Tomasz4292
    OK, but when I get the key from win 10, can I install win 10?
  • #6 16996547
    Pedros050
    Help: 2471
    Rate: 3926
    Yes it is.
  • #7 16997771
    Tomasz4292
    I meant something else ... I have this OEM license from a laptop with win10 installed.
    So if I take this key and give it to another computer it will be legal
  • #8 16997787
    kokapetyl
    Help: 1787
    Rate: 2101
    A colleague has already written.
    It cannot be a key used previously.
  • #9 16997876
    piotr.solek
    Help: 18
    Rate: 15
    I assume that you mean the key to Win7 because the "ten" is activated on a different principle. If you own both computers, the issue of legality no longer matters.
    I will just add that it may be necessary to contact a consultant by phone and activate it this way. I assume that the key is used only on one computer.
  • Questioning whether owning two PCs makes OEM reuse legal
    #10 16997945
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    In terms of legality - the OEM system license is assigned to the machine with which it was purchased and on which it was activated for the first time. Installation on another machine does not comply with the license.
    According to my colleague, does this mean that if I have two computers, it entitles me to illegally use the licensed software on the latter?
  • OEM license remains tied to the original machine
    #11 16998154
    piotr.solek
    Help: 18
    Rate: 15
    In this case (moderator's question) is no. We assume that the license is for one machine (
    Extending, he will quote because I'm not that "smart":
    "It all depends on the license in question. Licensing rules differ from country to country. In addition, there are several types of OEM and they differ depending on the product and country of origin of the license.
    The fact that a given user does not break European law does not mean that he is not breaking the license terms. At the same time, it is obvious that Microsoft's product licensing terms are in line with applicable law. "
    Well, everything is known :) )
The discussion revolves around the legality of using a Windows 7 OEM key to install Windows 10 on a different computer. Initial responses suggest that Windows 7 can facilitate the upgrade to Windows 10, but the key cannot be used on another machine as OEM licenses are tied to the original hardware. It is clarified that if a Windows 10 key is obtained, it can be used legally. However, using an OEM key from a different device violates licensing terms. The legality of using software on multiple machines depends on the specific licensing agreements, which vary by region and product type.
