Samsung Galaxy S6 Edge: Roaming Issue in Denmark - Not Registered to Network Error & Fixes
Dexios 3981 1
  • #1 16993599
    Dexios
    Hello. I am currently in Denmark and have a problem with my S6 Edge, namely roaming is not working. I have the roaming service turned on, I checked on other phones and everything was fine (the phone immediately connected to the network). My Samsung, when I try to search for networks manually, I find them, but I get the error "Not registered to the network, please try again later" when trying to connect. I also noticed that after restarting the phone, a small letter 'r' appears for a moment next to the signal strength (i.e. roaming works for a moment) and a few seconds later there is another loss of coverage, and then the phone catches the range without 'r' roaming. Tried factory reset phone to no effect. Other Danish SIM cards work normally on my phone, but I still have to check on some other Polish card if there is the same problem. Does anyone know how to fix this problem. Thank you in advance for your answer. :)
  • #2 17218911
    Lorga
    I had the same problem, I will add that on the T mobile network. But it turned out that it didn't matter.
    Enter:
    settings, mobile networks, turn off Data Roaming, Network operators, Search network, (info may appear disconnect network, click OK),
    Select a network operator from the list
    Please note that you can only use the network of an operator with whom (operator X) has a roaming agreement.
    Let me tell you that if you cannot turn off "Data Raoming", you should turn on the sim card of a foreign operator while abroad and then this option works. Then follow the instructions
    Good luck
