Garage Door Adjustment: Fixing Tilting Door, Drive Installation & Frame Rub Issues - 2 Years In
sanetrajakub 24297 14
Why does my garage door rub against the frame near the end of opening, and can it be adjusted?
Yes, it can usually be adjusted, and in this case the rubbing was caused by a distorted arm that held the door to the spring; straightening that arm fixed the problem [#16996999] Before finding that fault, it was suggested to check whether the drive was mounted exactly in the middle/axis of the door, because an off-center fastening can make a slightly crooked door cut into the frame at the end of travel [#16994329] It was also advised to verify the ceiling guides: both sides should have the same drop/level, the diagonals should match, and the automatic connector on the door should sit in the same position when the door is open and closed [#16995812] If those alignments are correct, look for any bent linkage or other mechanical deformation in the door/spring assembly [#16996999]
  • #1 16994023
    sanetrajakub
    hello, I have such a small problem I have a tilting door ..., has been installed for more or less 2 years, the problem is that I mounted the drive and everything would be ok, but the gate when opening, when it is almost open, rubs against its frame on the left there is no clarity what is the reason, when I close the gate, the actuator has to shed resistance and gate until it sheds but eventually it closes, what can be the reason, I will add that all risers and levels are preserved, the same with the guides are slightly bristling, but the quadrature is preserved, please help me, can such a gate be regulated anyhow ??
  • #2 16994075
    rafcio_21
    Help: 137
    Rate: 299
    Upload some photos and possibly a movie when the problem occurs.
  • #4 16994299
    rafcio_21
    Help: 137
    Rate: 299
    Do you have the drive mounted in the middle of the gate?
  • #5 16994322
    sanetrajakub
    I just got it right now when fixing the gate is about 1 cm in the right side of the screen, and can it be a reason ???
    rafcio_21
    Help: 137
    Rate: 299
    It can be as fastening is not perfectly in the middle of it is a slightly crooked gate.
  • #7 16994343
    sanetrajakub
    and it's really enough about 5 mm so that the place is next to this frame and everything will be ok, I will try, let me know or help you.
  • #8 16994630
    rafcio_21
    Help: 137
    Rate: 299
    Ok check if the drive is mounted in the axle, because if it is not it can also cut the gate in the final stage of opening. Best wishes and good luck in setting up.
  • #9 16994636
    sanetrajakub
    I checked the alignment, drive perfectly in the axis of the gate, and nothing else happens
  • #10 16994824
    rafcio_21
    Help: 137
    Rate: 299
    And if this guide on the left is solidly mounted on the video, it looks like it is being teleported with the gate.
  • #11 16994846
    sanetrajakub
    guides are mounted only at the ends, but quite solidly, to the wall and roof rafter, I do not know if they are to be level because I have a sensation as if they were at the factory with a slight drop, I'm surprised that there is no adjustment, because the gate is essentially without problems only in the final phase of how we would be curved, maybe these guides have to be held in two places, or to bend them to the ideal level, and in addition I thought that the gate in the middle is stuck and the floor no longer knows what can be,
  • #12 16995062
    rafcio_21
    Help: 137
    Rate: 299
    In previous work I assembled drives for gates but I do not remember if the drop was rather level, sometimes the guides were still stiffened and how you work the bearings in these guides can in the guide you have some rubbish through which bearings have to work harder.
  • #13 16995558
    sanetrajakub
    bearings are ok, there are no garbage, the problem is only in the last phase of opening and it surprises me, logic since with the frame from the center of the rail to the center of the rail I have 320cm, then at the end of the rail also so much maybe it splits the rail somewhere middle, and throughout the opening cycle is ok only the last 15 cm curves the gate?
  • #14 16995812
    Marek J.
    Help: 526
    Rate: 951
    Hinged gates are in themselves and because of the design they are not too rigid and can "swim" from one side to the other. Therefore, some manufacturers (I do not know if everyone) use the side or wings of the "sliders" of plastic to prevent the metal from rubbing against the metal ...
    A slight inaccuracy in assembly, leveling, spring tension and such things will take place. Check that the ceiling guides are correctly installed. It is about the same level / drop of both and "cross-over" - check diagonals from the corner of the left side of the hole to the end of the right guide and vice versa. The result should be the same. Also, see if the automatic connector (screwed to the gate) is in the same position / in the axis in relation to the guide of the machine (do it on the unlocked automaton) at the open and closed gate. If there is a difference, adjust the position of the machine to the left or to the right so that it is identical in both positions.
  • #15 16996999
    sanetrajakub
    nooo and the problem solved, it turned out that one of the arms that hold the gate to the spring was distorted, straightened now everything is elegantly elegant. Thank you very much for all your help, best regards
The discussion revolves around a tilting garage door that has been installed for two years, experiencing issues with rubbing against its frame during the final phase of opening. Users suggest checking the alignment of the drive and the mounting of the guides, as well as ensuring that the drive is centered. The problem was ultimately resolved when it was discovered that one of the arms holding the gate to the spring was distorted, which was straightened to restore proper function. Various troubleshooting steps were discussed, including checking for debris in the guides and ensuring that the guides are level and properly secured.
TL;DR: If your tilt‑up garage door rubs near fully open, focus on the last ~15 cm of travel; “the problem is only in the last phase of opening.” Check centerline mounting, guide alignment, and bent spring arms. [Elektroda, sanetrajakub, post #16995558]
Why it matters: This FAQ helps DIYers and installers quickly diagnose frame‑rub, skew, and opener alignment issues on tilt‑up/hinged garage doors.
How do I fix a tilt‑up garage door that rubs the frame near fully open?
Verify opener is centered, confirm both ceiling guides share the same level, and cross‑measure diagonals. Inspect spring link arms; a bent arm can pull the panel sideways. In the thread, straightening a distorted spring arm fully resolved the rub. “Fix the mechanical cause first, then fine‑tune alignment.” [Elektroda, sanetrajakub, post #16996999]
Why does rubbing only happen in the last ~15 cm of opening?
Small geometry errors show up at end‑of‑travel when linkages reach maximum leverage. The user observed smooth travel until the last ~15 cm, when the panel curved into the frame. That pattern points to off‑axis pull or a deformed linkage rather than debris. Focus inspection on link arms and bracket centering. [Elektroda, sanetrajakub, post #16995558]
Can a 1 cm off‑center opener bracket really skew the door?
Yes. An opener fastened off the centerline pulls the panel unevenly, which tilts the door and can cause frame rub. As one expert put it, if fastening is not perfectly in the middle, the gate goes slightly crooked. Re‑center the trolley bracket before other tweaks. [Elektroda, rafcio_21, post #16994329]
Should the drive be mounted exactly on the door’s center axis?
Yes. Check the drive is mounted on the door’s axis to prevent cutting or binding in the final stage of opening. Centering reduces lateral load on guides and hinges. After centering, re‑test full travel with the operator disengaged to feel for mechanical drag. [Elektroda, rafcio_21, post #16994630]
How do I verify guide alignment and crossover (diagonals)?
Measure both ceiling guides for equal level or drop. Then cross‑measure from the left opening corner to the right guide end, and vice versa. The diagonals should match. If not, adjust mounts or add stiffening before recalibrating the opener. “Check diagonals… The result should be the same.” [Elektroda, Marek J., post #16995812]
My guides are mounted only at the ends. Could flex be the cause?
Yes. End‑only mounting allows guides to move with the door, changing clearances at the top of travel. Add intermediate stiffening or brackets to lock the guide geometry. Re‑level after stiffening, then retest the cycle for smooth clearance. [Elektroda, sanetrajakub, post #16994846]
What photos or video help others diagnose my door problem?
Record the full open and close cycle, focusing on the last 20 cm. Include close‑ups of the center bracket, spring link arms, and both guides. Side shots showing the panel’s approach to the frame are especially useful for spotting skew. [Elektroda, rafcio_21, post #16994075]
Could dirty or failing bearings in the guides be to blame?
It’s possible. Verify bearings roll freely and that guides are clean. Debris can force bearings to work harder, adding resistance near end‑of‑travel. Clean the tracks, then recheck by hand with the operator disengaged to isolate mechanical drag. [Elektroda, rafcio_21, post #16995062]
What measurements should I compare when the door looks square but still rubs?
Compare guide levels and the two diagonals between opening corners and guide ends. Unequal diagonals indicate skewed geometry, even if bubble levels seem fine. Correct the structure first, then re‑teach opener limits if required. [Elektroda, Marek J., post #16995812]
How do I re‑center a slightly off‑axis opener the right way?
  1. Disengage the opener and place the door mid‑travel.
  2. Measure and mark the panel’s true center and the header’s centerline.
  3. Reposition the trolley rail and bracket to that line, then tighten and test by hand. Afterward, re‑engage and run a full cycle. [Elektroda, rafcio_21, post #16994630]
What does “tilting” or hinged garage door mean here?
It’s a one‑piece door that pivots on side arms and springs. These doors are less rigid than sectional types and can “swim” side‑to‑side under load. That characteristic makes precise guide alignment and centered drive mounting critical to prevent rubbing. [Elektroda, Marek J., post #16995812]
The levels look perfect, but rubbing persists—what’s the hidden culprit?
Check the spring link arms for bends or twists. In the thread, a distorted arm pulled the panel off‑track, causing contact only near fully open. Straightening that arm eliminated the issue immediately and permanently. [Elektroda, sanetrajakub, post #16996999]
Is 320 cm between rail centers acceptable if both ends match?
Equal spacing alone may not guarantee clearances. The user measured 320 cm center‑to‑center at mid‑rail and ends, yet rubbing appeared late in travel. That indicates geometry elsewhere—like diagonals or a bent arm—was the real cause. Verify those next. [Elektroda, sanetrajakub, post #16995558]
Do I need side sliders or plastic wear guides to prevent metal rub?
Many hinged doors use side or wing sliders made of plastic to stop metal‑on‑metal contact. If yours lacks them, consider adding wear guides after fixing alignment. They reduce noise and protect paint during minor deflections. [Elektroda, Marek J., post #16995812]
What’s an edge case that can fool even experienced installers?
A door can pass level checks and still rub because a single spring arm is slightly bent. The symptom appears only at the top of travel. Correcting that hidden deformation fixes the path without changing guides or opener settings. [Elektroda, sanetrajakub, post #16996999]
After centering and cleaning, it still binds at the end—what next?
Temporarily disengage the opener and hand‑cycle while watching both frame clearances. If the panel drifts left or right, recheck diagonals and arm straightness. If it stays centered by hand, revisit opener centering and bracket height. [Elektroda, Marek J., post #16995812]
