[Solved] Huawei B525 Port Forwarding: T-Mobile Fixed IP Address Setup & Tips for Configuration
abart68 18690 3
  • #1 16999065
    abart68
    Rate: 24
    I have internet in T-mobile and a fixed IP address
    I am asking for advice on navigating the ports, ie what to write in individual places in the table from port forwarding
    This equipment is Huawei B525.
    thanks in advance
  • #2 16999199
    jimasek
    Help: 3783
    Rate: 2681
    Standing does not mean public, so how is it?
    Explains external, internal ports and fixed LAN IP
    #3 16999365
    makosuu
    Help: 369
    Rate: 370
    Probably public, since he can not redirect the port, it does not surprise me that he just wrote a permanent one.
    And you do the table like this:
    External port: Here you enter the port from which you will connect to the outside, ie 8021 and then you connect, for example, 89.1.3.1:8021
    Internal port: here you enter the port on which this device works (eg if you enter 192.169.1.5 to get to the site, enter 80 in the internal port. If you are writing 192.168.1.5:8080, enter 8080 in the internal port)
    IP address: Here you enter the IP address under which this device is on the local network (you must give it a fixed IP so that it does not change at times, IP which you get to the device panel, i.e. 192.168.1.5)
  • #4 17827521
    abart68
    Rate: 24
    The problem was solved thanks to the forum member
