[Solved] BMW E39 520i 2.2L Engine Issue - Throttle Error A0 & A1 Codes, Stuck at 1200 RPM, Troubleshooting
ja3ol90 10341 11
  • #1 17001837
    ja3ol90
    Hello!
    I have a problem with the e39 engine 2.2 ben. Namely, my bunia fires very nicely and works freely. When I want to add gas it goes on 1200ob and it seems to choke and does not get higher.
    Throttle error came out from under the computer, more precisely: the engine throttle position controller - slightly blocked and then permanently locked. (Code: A0 and A1?)
    Error clearing enters 2 thousand revs and waves but reacts to gas.
    Throttles I replaced, cleaned. I also cleaned the crochet by the way. Everything is supported and the problem is the same.
    Maybe someone has encountered such a problem and will help :)
  • #2 17008081
    mateusz19896
    Hi, and which year do you have this e39, because after the engine capacity I deduce that you have an electric throttle?
  • #3 17008401
    ja3ol90
    Hi, 2001 ... so electrically controlled ... I exchanged for another and the same symptoms.
  • #4 17008488
    mateusz19896
    And if you don't get screwed up so it goes out or does it normally go after letting go of the gas? The question is how do the probes behave? Because if it is the fault of the fuel system, e.g. low pressure on the rail, the probes will be very poor.
  • #5 17008502
    ja3ol90
    I work very well on slow ... I press the gas goes to 1200rpm and chokes and waves ... releases the gas pedal goes even on slow
    And the topic of probes is probably turned off because nothing changes. The LPG oxide in the car may therefore not work
  • #6 17008514
    mateusz19896
    Do you have inpa or dis? To see how they oscillate and do they even oscillate?
  • #7 17008542
    ja3ol90
    I don't have anything special, just general autocom ...
  • #8 17008555
    mateusz19896
    Hmmmmm, it will be hard, because it's best to observe the parameters, e.g. if the resistance on the gas pedal increases smoothly, if the probes react, check if someone in the area has inpa'e and ask to connect the beemka. It will be easiest. Because you know ...
  • #9 17008559
    ja3ol90
    Ok ... something overwhelming ... and I will give a sign what and how
    Moderated By T5:
    3.1.13. Take care of language correctness and keep the rules of netiquette. Do not send messages from which it is difficult to deduce what their author wanted to convey.
  • #10 17008564
    mateusz19896
    Maybe during the weekend something will come to my mind I will write you something, but we are waiting for diagnostics.
    If you had m52, I would tell you to check throttles from asc, but you have an electric one, so one has 2 functions .... for curiosity, disassemble the throttle inlet, disconnect the flow, etc., see how you open the throat or open it to the full extent. And if you have it, check the pressure on the injection rail.
    Have a nice weekend!
  • #11 17124060
    kwiatek73
    Rate: 14
    Throttle adaptation. Should help.
  • #12 17233929
    ja3ol90
    Solved a problem ... Rotting and over burned bundle at the control computer plug
✨ The discussion revolves around a BMW E39 520i with a 2.2L engine experiencing throttle issues, specifically error codes A0 and A1, resulting in the engine being stuck at 1200 RPM. The owner reports that the engine runs well at low speeds but struggles to accelerate, choking when attempting to increase RPM. Various troubleshooting steps have been taken, including replacing and cleaning the throttle, but the problem persists. Participants suggest checking the fuel system for low pressure, observing throttle position parameters, and performing throttle adaptation. A final resolution was found to be a damaged wiring harness at the control computer plug.
TL;DR: BMW E39 520i 2.2L stuck at 1200 rpm can flag throttle “A0/A1” faults; “engine throttle position controller - slightly blocked and then permanently locked.” Root causes ranged from adaptation needs to a corroded ECU harness. [Elektroda, ja3ol90, post #17001837]
Why it matters: This FAQ helps 2001-era E39 owners quickly triage throttle faults without wasting money on unnecessary parts.
What do BMW E39 throttle codes A0 and A1 mean in this context?
In this case, the scan tool reported the throttle position controller as “slightly blocked,” then “permanently locked.” That points to an electronic throttle control fault, not a mechanical pedal issue. It also explains the limp-like behavior when pressing the accelerator. [Elektroda, ja3ol90, post #17001837]
Why is my E39 520i idling fine but stuck at about 1200 rpm on throttle?
The thread’s car idled normally but would climb to about 1200 rpm, then stumble and surge. That response suggests the ECU limits throttle opening due to detected throttle control or wiring faults, placing the engine in a protective mode. Clearing errors briefly changed behavior but did not fix it. [Elektroda, ja3ol90, post #17008502]
Did replacing the throttle body fix the problem?
No. The owner installed a different throttle body and cleaned the unit, yet symptoms persisted. This points past the throttle body itself and toward control, adaptation, sensor signals, or wiring. An edge case here is a damaged harness near the ECU, which ultimately proved true. [Elektroda, ja3ol90, post #17008401]
What actually fixed the car in the original thread?
The root cause was a rotted and heat-damaged wiring bundle at the engine control unit connector. Repairing the harness resolved the throttle errors and low‑rpm choking. Quote: “Rotting and over burned bundle at the control computer plug.” [Elektroda, ja3ol90, post #17233929]
Will a throttle adaptation help on a 2001 520i 2.2?
A contributor recommended performing a throttle adaptation as an initial remedy. Quote: “Throttle adaptation. Should help.” It is a low-cost step after battery disconnects, throttle swaps, or cleaning. If it fails, proceed to wiring and signal checks. [Elektroda, kwiatek73, post #17124060]
Is the 2001 E39 520i throttle electronic or cable-driven?
For 2001 520i 2.2, it is electrically controlled. The owner confirmed electronic throttle and had already swapped that assembly during troubleshooting, which narrowed the fault away from the physical throttle body. [Elektroda, ja3ol90, post #17008401]
How does the car behave after clearing the throttle error codes?
After clearing, the engine briefly revved to about 2000 rpm and surged but responded to the pedal. That transient change indicates the ECU temporarily resets learned states, yet the underlying fault quickly returns. This is typical when the root cause remains unresolved. [Elektroda, ja3ol90, post #17001837]
Should I check fuel pressure or the MAF before blaming the throttle?
Yes. A helper advised inspecting the intake path, temporarily unplugging the airflow meter, and checking rail pressure. These fast checks can distinguish airflow or fueling issues from throttle control faults, preventing misdiagnosis. [Elektroda, mateusz19896, post #17008564]
Do I need BMW-specific diagnostics like INPA or DIS?
Using INPA or DIS helps watch live parameters, pedal tracking, and sensor responses. The helper emphasized observing smooth pedal resistance values and probe activity. Generic tools may miss BMW‑specific data and adaptations. [Elektroda, mateusz19896, post #17008555]
What about oxygen sensors if the car has LPG?
The owner noted O2 probes appeared disabled on LPG, with no change when testing. That reduced immediate focus on mixture control and shifted attention to throttle control and wiring integrity for this case. [Elektroda, ja3ol90, post #17008502]
Can wiring cause throttle A0/A1 faults even if the car starts fine?
Yes. The car started and idled well, yet damaged wiring near the ECU caused persistent throttle errors and limited rpm. Electrical faults can selectively impair drive‑by‑wire while leaving base idle intact. [Elektroda, ja3ol90, post #17233929]
Quick 3-step check to avoid parts darts?
  1. Inspect throttle inlet and ensure the blade moves freely while commanded.
  2. Disconnect the MAF briefly to compare behavior.
  3. Measure fuel rail pressure to rule out supply issues.
    If unchanged, proceed to adaptation and harness inspection. [Elektroda, mateusz19896, post #17008564]
