Indesit IWSC 51051 C ECO PL: Seeking Dimensions for Bearings and Seals Replacement
talbotsolara 4131 6
  • #1 17005097
    talbotsolara
    Rate: 12
    Hello, I need the dimensions of the bearings and seals, the old ones have fallen apart.
  • #2 17005146
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3368
    The manufacturer did not provide for the replacement of bearings, only the entire tank, so this data is not available. When you cut open the tank, you'll see what's there.
  • #3 17005153
    Pawpraw
    Help: 7
    Rate: 39
    Bearings 6204 and 6205 and Simmerring 30x52x8.5 / 10.5 for the Indesit IWSC 51051 CECO washing machine.
  • #4 17005154
    talbotsolara
    Rate: 12
    Well, I'm scattered, I would have to measure everything ...
  • #5 17012516
    talbotsolara
    Rate: 12
    The big one fits, but the smaller one does not, it goes into the housing, but the shaft is smaller, what do you do as the shaft in the place of the large bearing is a bit already worn, I skip welding and later machining, maybe knurling, maybe there is an easier way?
  • #6 17829734
    Maver2705
    I have a problem with this washing machine, namely the bearings.
    Can you replace them yourself at all?
  • #7 17829820
    Dziarski Hank
    Help: 246
    Rate: 931
    Well, you have it in the second post.
✨ The discussion revolves around the Indesit IWSC 51051 C ECO PL washing machine, specifically regarding the dimensions needed for replacing bearings and seals. One user notes that the manufacturer does not provide replacement dimensions for bearings, suggesting that the entire tank must be replaced instead. However, another user provides specific dimensions for the bearings (6204 and 6205) and the Simmerring (30x52x8.5 / 10.5). Follow-up messages indicate challenges with fitting the smaller bearing due to a worn shaft, leading to considerations of welding or machining as potential solutions. There is also a query about the feasibility of self-replacing the bearings.
