Connecting Terrestrial TV to MSI GP60 Laptop: Using Decoder Ferguson Ariva T65 & TV Cards
wegen213 6183 12
How can I connect terrestrial TV from a wall antenna socket to an MSI GP60 laptop, and can I use a Ferguson Ariva T65 decoder for it?
You cannot do this through the laptop’s HDMI, because the laptop has HDMI output only, not input; the practical solution is a USB DVB-T TV tuner/card. Install the tuner’s drivers and viewing software, then connect it to the existing antenna socket and scan for channels [#17005407][#17006073] If the antenna is already working with other TVs and the signal is good, it should be enough to plug in the USB tuner and search for channels, since DVB-T channels are not scrambled [#17005415] Be aware that cheap USB tuners can be sensitive and may fail to find channels if reception is weak [#17007666]
  • #1 17005356
    wegen213
    Good morning!
    I started the topic because I didn't find the right answer.
    I would like to learn how to connect terrestrial TV to a laptop. I have MSI GP60. In the room I have a socket for receiving terrestrial TV (antenna next to the house). So I don't need a laptop antenna. So how do you connect it? Need to buy some TV cards? Can I use a decoder from tv: Ferguson ariva t65?
    qs300
    Help: 242
    Rate: 362
    How do you want to connect the decoder to the laptop?
  • #3 17005380
    wegen213
    There is an HDMI input, I don't know if it is possible. I just came up with the idea of TV in my laptop.
    icosie
    Help: 298
    Rate: 239
    Certainly not exit HDMI input on a laptop.
    You need a TV card with DVB-T to USB.
    Edit: typo corrected
  • #5 17005414
    wegen213
    And that's all to fix the topic? ;)
    icosie
    Help: 298
    Rate: 239
    If the antenna is well positioned and is receiving something, it is enough to connect the TV card to the USB, install the drivers and the program that will handle it, find the channels and you can watch.
    There is no philosophy here because the channels are not scrambled.
  • #7 17005429
    wegen213
    Dovra, thanks. It certainly works, two televisions are already connected to this antenna. Is there any device up to PLN 50 worth attention?
    icosie
    Help: 298
    Rate: 239
    I used to use Not Only TV, but that's before the digital age.
    It had a quite extensive player and allowed to record from other devices, e.g. an analog camera or a VHS player.
    Now I can see that it costs a little more than PLN 50.
    I don't have much experience with DVB-T, so I won't give you a tip.
    kazikszach
    Help: 516
    Rate: 1105
    icosie wrote:
    There is definitely no HDMI output on the laptop.
    Where did you get this information from, because it's total nonsense?
    There is only an HDMI output, not an input.
  • #10 17006568
    icosie
    Help: 298
    Rate: 239
    Sorry, typo, obviously the thing was that the laptop has no input. Thanks for paying attention.
  • #11 17007666
    KOCUREK1970
    Help: 3865
    Rate: 5498
    @ wegen213
    You must be aware that all these USB tuners have brick sensitivity - it may turn out that the tuner will find nothing.
  • #12 17010034
    wegen213
    Hmm, I understand there are better ways?
  • #13 17010048
    KOCUREK1970
    Help: 3865
    Rate: 5498
    Of course, but not for a laptop.
To connect terrestrial TV to an MSI GP60 laptop, a USB TV card with DVB-T capability is required, as laptops do not have HDMI input. Users can connect the TV card to the USB port, install the necessary drivers and software, and then scan for channels. The Ferguson Ariva T65 decoder is not directly applicable for this setup. While some USB tuners may have sensitivity issues, they can still function if the antenna is properly positioned. A budget of around PLN 50 may limit options, but users have previously utilized devices like Not Only TV, although they may exceed this price range.
TL;DR: Want live terrestrial TV on an MSI GP60? 1 USB DVB‑T tuner solves it. "You need a TV card with DVB‑T to USB." [Elektroda, icosie, post #17005407]
Why it matters: This FAQ helps laptop owners quickly choose the right hardware and avoid HDMI‑input myths.
How do I connect terrestrial TV to an MSI GP60 laptop?
Use a USB TV tuner that supports DVB‑T. Connect it to the laptop, attach the room’s antenna feed, install drivers, then scan channels. This replaces the absent HDMI input and lets you watch broadcast TV directly on the GP60. [Elektroda, icosie, post #17005407]
Does the MSI GP60’s HDMI port accept video input?
No. The HDMI on consumer laptops works as an output only, so it cannot display video from a decoder or console. "There is only an HDMI output, not an input." [Elektroda, kazikszach, post #17006073]
Can I use my Ferguson Ariva T65 decoder with the laptop over HDMI?
No. The laptop lacks HDMI input, so the Ariva T65’s HDMI cannot feed video into the GP60. Use a USB DVB‑T tuner instead to receive terrestrial TV directly on the laptop. [Elektroda, icosie, post #17005407]
What software do I need after plugging in a USB tuner?
Install the tuner’s drivers and its viewing app, then run an automatic channel scan. Broadcasts are free‑to‑air, so no decryption step is needed. [Elektroda, icosie, post #17005415]
Will a USB DVB‑T stick under PLN 50 do the job?
Plan to spend more than PLN 50. Even older, well‑known sticks exceeded that price point, and ultra‑cheap options often cut corners. [Elektroda, icosie, post #17005442]
Why does my USB tuner find zero channels?
Some sticks have very low sensitivity—users call it “brick sensitivity.” If reception is marginal, the scan returns nothing. Improve the antenna feed or try a better tuner model. [Elektroda, KOCUREK1970, post #17007666]
Are DVB‑T channels encrypted?
No. Local terrestrial channels arrive unencrypted, so once drivers and software are installed, a standard scan should populate your channel list. [Elektroda, icosie, post #17005415]
Is there any better method than a USB tuner for laptops?
For laptops, no. Alternatives can be better for TVs, but for a GP60, a USB DVB‑T tuner is the practical route. [Elektroda, KOCUREK1970, post #17010048]
Do I need a separate antenna if I have a wall socket?
No. If the existing antenna installation delivers signal to that socket, connect it to the USB tuner, install software, and scan channels. [Elektroda, icosie, post #17005415]
Quick setup: how do I start watching in minutes?
  1. Plug a DVB‑T USB tuner into the GP60 and connect the antenna cable.
  2. Install the tuner’s drivers and viewing app.
  3. Run Auto‑Scan and start watching the found channels. "There is no philosophy here because the channels are not scrambled." [Elektroda, icosie, post #17005415]
What does “DVB‑T USB tuner” mean here?
In this thread, it’s a USB device that receives digital terrestrial TV (DVB‑T) from your antenna and lets the laptop display it after a channel scan. [Elektroda, icosie, post #17005407]
Can these tuners record TV on a laptop?
Yes, many tuner apps include recording. Older sticks from brands like Not Only TV even offered extensive players and recording features. Expect current models to provide similar basics. [Elektroda, icosie, post #17005442]
