Goodram CX300 SSD Firmware Update: Software Recommendations & Instructions
hynio82 14241 15
How can I update the firmware on a Goodram CX300 SSD, and what software do I need?
You need the Linux firmware package from Goodram and must perform the update from a Linux system, not Windows [#17036103][#17024603] Goodram said there is currently no Windows version for this model and warned that the update deletes all data, so make a backup first [#17036103] One reply says the archive contains the executable `Reinitial_SBFM711_V1` and suggests booting a Linux Live system, ensuring the CX300 is visible and mounted, then running the unpacked program [#17037609]
  • #1 17005726
    hynio82
    Hello. Maybe someone knows what software to upload the SSD Goodram CX300 firmware ??
  • #2 17005786
    sylweksylwina
    Help: 1882
    Rate: 2355
    Typically, the software is appropriate from the firmware.
  • #3 17016416
    hynio82
    Officially on the manufacturer's website there is no FW to this disk. FW I received from the producer but I received information that it can be uploaded only under linux but I do not know how.
  • #4 17016500
    mbo
    Help: 2333
    Rate: 845
    Ask the manufacturer for instructions on how to upload this firmware.
  • #5 17016536
    hynio82
    I asked ... but all this is going on ... and I do not know when I will answer
  • #6 17017702
    Łukasz_W
    HDD and data recovery specialist
    Help: 633
    Rate: 658
    The producer sent the file but did not send instructions on how to use it?
    Interesting...
    HEX SERWIS
    Smołdzinska 2B/16, Kobysewo, 83-304 | Tel.: 530XXXXXX (Show) | Company Website: https://hex-serwis.pl
  • #7 17018450
    melanchel
    Help: 154
    Rate: 380
    Post it on the forum, add an attachment and describe which FW is to be updated.
  • #8 17021603
    max-bit
    Help: 117
    Rate: 857
    Probably the producer will not send anything because uploading takes place in the factory through the JTAG interface
    And not software for wines :)
    And after all, why do you want to upload some software?
    If prod does not place it on the site, it means that such a procedure is (probably) unnecessary.
  • #9 17024603
    hynio82
    The manufacturer sent me an e-mail firmware to work with the Nvidia MCP79 chipset. In the e-mail, the producer mentioned that the firmware update only takes place from the Linux system level. Detailed instructions on how to do this have not been given. SATA devices in the MCP79 chipset are not handled correctly. Correct operation is to be provided by this firmware.
  • #10 17024674
    max-bit
    Help: 117
    Rate: 857
    hmm if he did not send instructions, it's hard to say how to do it.
    After that Nvidia MCP79 is probably a bridge ... and not a chipset in the disk.
    And we still do not know why this update should take place?
    There is a program on the page ... smart_goodram? But does he support ... well, not if the producer wants us to do it after linux.
    After that, it's strange, the manufacturer sends a firmware that wants us to do it under linux without any instructions :)
    I'm sorry, but it's very strange ... was someone in goodram gone out of his mind?
  • #12 17036103
    hynio82
    As I wrote earlier, the manufacturer sent me an e-mail firmware which should work with the Nvidia MCP79 bridge. In the e-mail, the producer mentioned that the firmware update only takes place from the Linux system level. There was nothing more in the mail. As I asked for instructions, he has not written back so far. In the attachment of the firmware that I received. Below is an e-mail quote:
    We currently do not have a Windows version for this model.
    In the attachment we send a version for Linux.
    Please keep in mind that the update deletes all data on the disk. Therefore, please make a copy of the data before you change the disk software.
    Technical Department
    support(_at_)goodram.com
    • Reinitial_SBFM711_V1.tar.gz (1.76 MB) You must be logged in to download this attachment.
  • #13 17037609
    adamjk
    Help: 126
    Rate: 151
    Inside the uploaded archive is the executable file Reinitial_SBFM711_V1 (4306584 bytes). It seems that you need to run a Linux version of Live and if the CX300 drive is visible, mount it and then run the unpacked above program.
  • #14 17037684
    sylweksylwina
    Help: 1882
    Rate: 2355
    Probably not entirely:
    Screenshot with a bash error message about an invalid executable file format.
  • #15 17037900
    WojtasJD
    Help: 2919
    Rate: 1586
    Z pod 64-bit Manjaro - Budgie:
The discussion revolves around the firmware update process for the Goodram CX300 SSD. Users express difficulty in finding appropriate software for the update, as the manufacturer has not provided a Windows version. The firmware received from Goodram is intended for use with the Nvidia MCP79 chipset and requires a Linux environment for installation. Users suggest contacting the manufacturer for instructions, but many report a lack of guidance. One user mentions that the update process may involve running a specific executable file in a Linux live environment, which could lead to data loss. The conversation highlights the challenges faced by users in updating the firmware without clear instructions from the manufacturer.
TL;DR: Goodram CX300 firmware is updated via Linux only—“We currently do not have a Windows version for this model.” One OS supported (Linux). Use the Reinitial_SBFM711_V1 tool. Back up first. [Elektroda, hynio82, post #17036103]
Why it matters: This FAQ helps CX300 owners fix MCP79 SATA issues and safely run the Linux-only updater.
What software updates the Goodram CX300 firmware?
Users received a Linux archive containing an executable named Reinitial_SBFM711_V1 for flashing the CX300. [Elektroda, adamjk, post #17037609]
Is there a Windows firmware tool for the CX300?
No. Goodram support stated, “We currently do not have a Windows version for this model,” and provided only a Linux build. [Elektroda, hynio82, post #17036103]
Why would I need this update on certain laptops or desktops?
It addresses SATA handling problems with systems using the Nvidia MCP79 bridge, improving CX300 compatibility. [Elektroda, hynio82, post #17024603]
How do I run the Linux updater for CX300? (3-step How-To)
  1. Boot a Linux Live USB and ensure the CX300 is connected.
  2. Extract the archive and locate Reinitial_SBFM711_V1.
  3. Run the executable and follow on-screen instructions to reinitialize firmware. [Elektroda, adamjk, post #17037609]
Does the tool work on modern 64‑bit Linux distros like Manjaro?
Yes. A user launched it on 64‑bit Manjaro Budgie and shared a screenshot of successful execution. [Elektroda, WojtasJD, post #17037900]
What problem symptoms point to the MCP79 issue the update targets?
SATA devices may be handled incorrectly under the MCP79 bridge, causing recognition or stability issues with the CX300. [Elektroda, hynio82, post #17024603]
Where can I get the CX300 firmware if it’s not on the website?
Request it from Goodram support; users received the Linux package by email when the site lacked a download. [Elektroda, hynio82, post #17016416]
What’s inside the package Goodram sent for Linux?
Reports show the archive contains an executable named Reinitial_SBFM711_V1 (~4.3 MB) intended to reinitialize the drive. [Elektroda, adamjk, post #17037609]
Can I use Goodram’s SMART tool instead of the Linux updater?
One user mentioned a SMART utility, but the vendor directed CX300 owners to the Linux updater for firmware changes. [Elektroda, hynio82, post #17036103]
Is factory-only (JTAG) flashing required for CX300 firmware?
A community member suggested factory JTAG flashing, but others used the Linux executable shared by support. [Elektroda, max-bit, post #17021603]
How can I verify the controller/firmware before flashing?
You can check with Phison SATA Toolbox to view controller and firmware details for the CX300. [Elektroda, pidar, post #17038094]
What if the manufacturer doesn’t send instructions?
Ask Goodram for official flashing steps. Community members recommended requesting detailed guidance from support. [Elektroda, mbo, post #17016500]
Can I share the firmware on forums to get help?
Yes, a member suggested posting the file and describing the exact CX300 firmware to be updated for guidance. [Elektroda, melanchel, post #17018450]
Any usage tips before I run the tool?
Back up everything, connect the CX300 directly over SATA, and run the Linux executable as instructed by support. “Back up first.” [Elektroda, hynio82, post #17036103]
What does the on-screen usage look like when the tool starts?
Screenshots show command-line usage output when launching the Linux updater, confirming it’s a CLI utility. [Elektroda, sylweksylwina, post #17037684]
