I warmly welcome. Unfortunately, I do not have a remote control for the cinema and only L, R and SW speakers are playing, it can be changed without a remote control at the cinema. Or maybe someone has a remote for sale or knows what it would have to be? Best regards and thank you for any suggestions
Hello. The proposed operation of this home theater from the Android application does not allow you to enter the sub-settings, only the basic ones, and I know because I had the same case. My suggestion is that you will look for such a remote control on the Internet by entering this number under one of the pictures. A59-0197. do not buy cheap substitutes proposed, e.g. on Allegro, with white ones with a flap, because if you want to operate the cinema from this remote control, you will have to open and close the flap, which is bothersome. I do not recommend it. Added after 4 [minutes]: Hello. It is supposed to be AH59-0197E Added after 6 [minutes]: Hello. You can easily buy this offer https://www.olx.pl/oferta/pilot-samsung-model-ah59-oryginalny-CID99-IDt2mUB.html#df5c92050d
The discussion revolves around the Samsung HT-THQ22 home theater system, specifically addressing the issue of operating the system without a remote control. The original poster seeks advice on how to change the number of speakers being used, as only the left, right, and subwoofer speakers are functioning. Suggestions include performing a factory reset and using an Android app with an infrared port to access remote control functionalities. However, it is noted that the app may not allow access to all sub-settings. The recommended solution is to purchase the original remote control model AH59-0197E, with warnings against using cheap substitutes that may hinder usability. A link to a potential purchase is also provided. AI summary based on the discussion. May contain errors.
