LG 55UJ620V - optical output control with a TV remote control
tgawron 10005 4
  • #1 16948275
    tgawron
    I recently bought a TV from a theme that is connected to the receiver - sound to the receiver through the optical output on the TV.
    Everything would be nice, but it turned out that with this configuration I can not control the sound with the TV remote, i.e. the optical output.
    To control the volume I have to use the remote control of the receiver.
    If any of you could help, I would be grateful.
    best regards
  • #2 16948360
    Polon_us
    Help: 1184
    Rate: 1280
    It is not possible to control the sound level at the optical output of the TV.
    A simple convenience is programming the amplifier control (basic functions) in the TV remote control.
    Or vice versa - controlling the TV with the amplifier remote control.
    Another solution would be to connect the TV and the amplifier with an HDMI cable as long as the amplifier has + built-in control functions.
    My friend did not give the amplifier model, so for now it is only a guess.
  • #3 16948462
    tgawron
    And this surprises me, because in the past I had a dvbt decoder with an optical output, in which I could adjust the volume level on the decoder remote.
    In my case, it is best to turn on / off and sound + and - (can I ask for info on how to do this?)
    I did not give it, because I was hoping that the volume level at the optical output of the TV would be controlled (then the type of amplifier would not matter).
    The amplifier is the Sony STR-KSL50, available digital inputs, optical and coaxial.
  • #4 16949235
    Polon_us
    Help: 1184
    Rate: 1280
    tgawron wrote:
    (can I ask for info on how to do it?)
    I think that the TV / remote control manual should explain how to do this.
    The amplifier is quite old, if we talk about technological advances, and cannot be used for HDMI control.
  • #5 16987507
    tgawron
    In my spare time I was looking for some information on this topic but unfortunately I could not find the answer.
    I have a TV remote control LG AKB75095308 and I would like it to just turn down the sound on the Sony STR-KSL50 amplifier.
    I am not sure if this is possible at all.
    I will be grateful for your help.
    PS
    If the TV had any analog output, such a solution would be enough for me, because the amplifier very nicely "transforms" the sound into 5.1
