KIA SPORTAGE 2.0 CRDI - Timing belt replacement KIA SPORAGE 2.0 CRDI.
henryk777 24057 3
  • #1 17023967
    henryk777
    Rate: 36
    Hello, it's exactly about KIA SPORTAGE 2005. 2.0 crdi do you need to remove the motor ????
    Hehu
    Registration: 13 mins ago
    Moderated By CameR:
    Reg. 3.1.13. Take care of linguistic correctness and keep netiquette rules. Do not send messages from which it is difficult to deduce what their author wanted to convey.
  • #3 17024179
    henryk777
    Rate: 36
    The description applies to the 2007 model. I have a 2005 model. and the problem is that I can not pull out the motor cushion, it is unscrewed from the engine block, the engine is raised to the max and the stand does not want to go out and I wonder if you do not need the engine to completely remove ???????
    Added after 8 [hours] 59 [minutes]:
    I am just after replacing the timing belt and my short observation ..... I would like to personally get to know this "constructor genius" of the engine, total constructional thoughtlessness !!!!! The first and last time 2.0 CRDI ....
  • #4 17121046
    lysyrob
    Rate: 10
    This is not the end of what may surprise this engine ...
