Wifi PremiumBox+ Unicable Support: Settings, Compatible Converters & User Experiences
andpol 33 10539 8
  • #1 17024428
    andpol 33
    Help: 513
    Rate: 1146
    Well, supports, or not because I think I caught sight and do not see the settings? Someone was connecting? What converters works well with?
  • #2 17024702
    Pedros050
    Help: 2471
    Rate: 3927
    Yes, Premiumbox + wifi supports Unicable (sometimes the decoder can display a message about no signal for a very short time).
    The options for starting operation in the AERIAL menu are exactly the same as in turboBOX + (some series of this decoder have a problem when switching channels). The same requirements are also the same: connection of two antenna signals and restrictions: no possibility of receiving signals from the Astra satellite.
  • #3 17027535
    andpol 33
    Help: 513
    Rate: 1146
    "Hello.
    Regards.
    nOlsbit "
    Why are you sending me a quote from the NC + forum from 2015? The rest of this topic indicates that it does not work properly with the Inverto converter. Did you check personally? So now I think that the "single-cable mode" option must appear after switching to 2 antennas. The question was, did anyone check the unicable functionality of this decoder? And on what converter?
  • #4 17029321
    andpol 33
    Help: 513
    Rate: 1146
    Okay, I've read that "single-cable mode" appears only when set to 2 antennas. Nobody really connected this decoder to unicable? How does this work in practice? Which converter is doing the best?
  • Unicable converter with legacy second output
    #5 17029985
    netTv
    Level 32  
    Help: 193
    Rate: 579
    A Unicable converter is enough, https://www.eltrox.pl/tv-i-multimedia/telewiz.../konwertery/konwerter-blue-line-unicable.html
    You connect the Unicable signal via splitter to both SAT WiFi premium box's satellite antenna inputs
    In single-cable mode, you set a different frequency for each of the four inputs: 1210 MHz, 1420 MHz, 1680 MHz, 2040 MHz
    In the case of this converter, you can still connect a decoder, e.g. WiFibox, as a multiroom. The WiFi box does not support Unicable technology, so you need to connect it to the second output with a legacy signal, i.e. a traditional one like in a regular converter.
  • #6 17096786
    digitaltech
    Rate: 13
    If I can add my three grosze, I have been dealing with satellite installations for many years, I was dealing with such a converter, it came out very pale, with the new antenna of 80cm diameter from Corab MER of course on the most interesting transponders 11,449GHz MER 12 dB and 11.508 GHz 11.5 dB, after converting to ordinary Single Inverto from 10 years ago MER 14.8 dB and 14.4 dB, respectively. Poor results were on the unicable connector and on the conventional universal. Unicable Inverto is definitely better, although worse art can always happen.
  • #7 18344541
    girgi
    Rate: 9
    A little dig up but the topic fits and I would like to make sure ...
    I just called Canal + with a question about Unicable support via Wifi Premiumbox + and I was told categorically NO - it doesn't support Unicable and from their set-top boxes only the most expensive Ultrabox + has this option.
    Can anyone confirm or deny?
    Maybe it's their marketing trick or what?
  • #8 18344682
    _kli_
    Help: 762
    Rate: 1040
    On their Technical Support page you have ...
    pl.canalplus.com wrote:
    Converters with one output called Unicable , SCR or dCSS - are intended for connecting one decoder 4K UltraBox +, Wifi Premiumbox + , mediaBox +, turboBox +, Box + 2849/50 / 51S or after using the splitter of several of the previously mentioned decoders.
    https://pl.canalplus.com/pomoc/jaki-konwerter...y-maksymalnie-wykorzystac-mozliwosci-dekodera
    Last time I plugged it in last year and so far I haven't had information to stop working.
  • #9 18344702
    girgi
    Rate: 9
    https://pl.canalplus.com/pomoc...ykorzystac-mozliwosci-dekodera
    And that was what I meant. If such a system works, it means that either the consultants on the hotline are uninformed or are spinning something.
    edit:
    Unless this option is blocked in currently released decoders but this seems unlikely.
The Wifi PremiumBox+ reportedly supports Unicable technology, although users have experienced intermittent issues such as brief "no signal" messages. To utilize Unicable, it is necessary to connect two antenna signals and configure the system to single-cable mode, which activates when set to two antennas. Various converters have been discussed, with some users noting that the Inverto converter may not work effectively. A specific Unicable converter was recommended, which allows for multiple frequency settings for different inputs. However, there are conflicting reports regarding the official support for Unicable by Canal+, with some users stating that only the Ultrabox+ supports this feature. Overall, user experiences vary, and further testing with different converters is suggested.
