[Solved] BMW E46 316i 1999 - After the battery is replaced, the central locking system do
Chupacabra 22710 15
How do I restore the BMW E46 key’s central locking remote after replacing the battery, and does it need separate programming in another module?
No separate alarm-module programming is shown here; the immobilizer and the remote central-locking circuit are different parts of the key, so if the engine starts but the buttons do nothing, the RF remote section is likely not transmitting or has been damaged during the battery swap [#17186647][#17030508] The usual initialization is: close the door, turn the ignition to position 1 and back within 5 seconds, then hold unlock and press lock three times within 10 seconds; a successful sync is confirmed only when the central locking closes and opens once [#17030544] If there is no such reaction, the key should be checked to see whether it actually emits radio waves, because a dead transmitter will not respond to coding attempts [#17030508] One reply also suggests checking the key with a key manager/service to verify that the key is suitable [#17186508] In the thread’s final outcome, the key set was replaced and the new key worked, which points to a faulty key rather than a hidden comfort/alarm module [#17316731]
  • #1 17030162
    Chupacabra
    Help: 247
    Rate: 867
    Hello!
    I have two keys for a car of this type:
    Some time ago, I wanted to replace one battery, because its operating range (opening the car) was very short and the battery (accumulator) gave signs of wear. After replacing the battery, I programmed both keys as the manual says and it turned out that the central lock does not respond to this key with the replaced battery and the car runs without any problem on it. Multiple programming has not helped. I suspect that the central lock is connected to a separate alarm module, because the car has some alarm output and under the hood sits such a standard mermaid:
    In the previous car, the alarm control panel was pressed under the steering column. I undressed all the covers under the steering wheel, undressed the entire passenger compartment, and nothing was found beyond the standard BMW components (EWS, relay box). Interestingly, when I close the car by inserting the blade into the lock, the alarm goes into standby mode. And as I open this way, the locks will be unlocked and the alarm starts to go to the booth and I will not remove it with the button on the key.
    Question:
    Is it possible that I need to program this key somewhere besides the immobilizer, in other words in the alarm control unit?
    Where else can this control unit be stuck? Finding along the cord from the mermaid does not give anything, because he dies in the channel with other wires under the hood.
    Thanks in advance for your help, because the second key would come in handy.
  • #3 17030544
    Chupacabra
    Help: 247
    Rate: 867
    When you program it in immo, you have to press a sequence of keys, which is confirmed by the car. And from here I assume that the remote control emits a signal.
    [Quote from the network]
    1. Go to samocruv and close the door
    2. Insert the ignition key and turn it to position No. 1 (the AIRBAG indicator lights up) max. 5 sec. and remove the key back
    3. Press and hold the opening button. Without releasing this button, press the button briefly, three times within 10 seconds
    4. Release the opening button if the attempt is successful, the central will close and open immediately.
    In the absence of a central locking reaction, the pilot must be re-initialized.
    If you have other keys with a remote control (a total of 4 items for this car !!), you must also initialize them, each within 30 seconds after the previous one.
    [End quote]
    Whether I program it first or second, there is always a reaction.
  • #4 17030589
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    What reaction?
    This is the only reaction the instruction assumes.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #5 17030603
    Chupacabra
    Help: 247
    Rate: 867
    Well, that's what's happening. And then the central one does not respond to any of the buttons.
  • #6 17036782
    Chupacabra
    Help: 247
    Rate: 867
    I tried the home methods described here on the forum to check if the pilot sows and I have doubts. I will try it somehow to check and I will be able to know it 100% sure. I am just wondering that it is programmable and a reaction to the buttons is needed.
  • #7 17096656
    Chupacabra
    Help: 247
    Rate: 867
    I had a moment to bury. The pilot seems not to sow. I wonder if I did not hurt him by exchanging the original 3.0V battery for the portal 3.6V. I have 4.0V on the power supply, measuring it with a meter. This 1.0V too much could probably do.
  • #8 17152157
    Chupacabra
    Help: 247
    Rate: 867
    I used to play with a laptop with the INPA program today and the situation is as follows: Both keys can be programmed easily, both keys and their numbers are visible through the EWS and with both keys the car drops out without any error. Well, unfortunately, what I would not do is the car does not react to closing / opening of this key with the replaced battery (except for the only situation where after programming the key central locking confirms the correctness of the procedure).
    I read somewhere that the keys can also be programmed separately for the comfort module. Is it true?
  • #9 17185026
    umyk2
    Rate: 11
    He is struggling with the same problem. The car does not respond to the key. You can open the door with the arrowhead but with a zero reaction button. I replaced the battery in the remote control yesterday because the old one was already working only after approaching the door and last week it stopped working completely. The car fires. I also tried to code or adapt the key by putting it in the ignition and then pressing the buttons as everyone recommends. Nothing gives zero reaction. The central lock still does not react. I was looking for answers in other forums but nobody knows anything. I have only one key for this car. I did not damage the tiles when cutting the housing (I looked closely). Can anyone remedy this?
  • #10 17185160
    Chupacabra
    Help: 247
    Rate: 867
    And he could be programmed normally?
  • #11 17186469
    umyk2
    Rate: 11
    I can not initiate this key. I sat today after work for half an hour under the block, getting on and off, repeating the whole procedure over and over again to boredom. The buttons do not react anymore. It crossed my mind to go to the masters from BMW but recently I left 4100 PLN for them. Probably I would not know the problem anyway. The battery that I soldered has a rated voltage of 3.6V so I wonder if this is not a problem but if you post previous posts, it probably does not matter.
  • #12 17186508
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6421
    Go to the key manager and check if the key is suitable.
  • #13 17186608
    Chupacabra
    Help: 247
    Rate: 867
    And in my case the key reacts to programming, immo recognizes its code, the engine can be started and the buttons after programming become dead. I wanted to replace the battery in the second one, but I'm afraid it will be the same.
  • #14 17186647
    Help: 1404
    Rate: 6421
    Immo and the remote control cz are two different circuits in the remote control.
  • #15 17186657
    Chupacabra
    Help: 247
    Rate: 867
    I know that. But when programming the remote control you use a sequence of buttons. The car responds to you by clicking the central button. And with me the whole procedure goes perfectly and then meatball. As if the comfort module did not see / recognize the key.
  • #16 17316731
    Chupacabra
    Help: 247
    Rate: 867
    As a result of the immo fault, the entire set with the key was replaced. The new key works + one old one.
✨ The discussion revolves around issues with the central locking system of a 1999 BMW E46 316i after replacing the battery in one of the remote keys. The user reports that, despite programming both keys according to the manual, the central locking does not respond to the key with the new battery. Various troubleshooting steps are suggested, including checking if the remote emits radio waves, reprogramming the key, and verifying the battery voltage. Some participants mention that the remote control and immobilizer circuits are separate, indicating that the key may be recognized by the immobilizer but not by the comfort module for central locking. The user suspects potential damage from using a higher voltage battery and considers consulting a professional for further diagnosis.
TL;DR: E46 supports up to 4 remote keys, and "In the absence of a central locking reaction, the pilot must be re-initialized." Fix post-battery-change no-remote issues by re-initializing, verifying RF output, and using the correct 3.0V cell. [Elektroda, Chupacabra, post #17030544]
Why it matters: It helps BMW E46 owners restore remote locking after a battery swap or coding attempt fails.
Why does my E46 key start the car but the buttons don’t lock/unlock after a battery change?
Because the immobilizer and the RF remote are separate circuits. The EWS chip can work while the transmitter is dead. Re-initialize the remote and verify it actually transmits RF. “Immo and the remote control are two different circuits.” If it still fails, suspect the fob’s RF section or wrong battery choice. [Elektroda, Strumien swiadomosci swia, post #17186647]
How do I reprogram (initialize) my BMW E46 remote key fob?
Use the in-car sequence.
  1. Sit inside, close doors; turn key to position 1 (<5s) and remove.
  2. Hold unlock; press lock three times within 10 seconds; release unlock.
  3. Locks should close and open once; repeat step 2 for other keys within 30 seconds. This confirmation shows the car accepted the sync. [Elektroda, Chupacabra, post #17030544]
My E46 confirms programming (locks cycle), but the buttons still do nothing—what next?
That pattern points to a non-transmitting fob. Measure the battery voltage and confirm the correct 3.0V cell. A reported 3.6V swap measured ~4.0V and the remote stopped “sowing” (transmitting). Inspect solder joints and the RF section. Test with an RF detector or at a locksmith. Replace the cell with the proper type if overvoltage occurred. [Elektroda, Chupacabra, post #17096656]
Does the immobilizer (EWS) need different programming than central locking?
Yes. EWS stores key IDs for starting. The remote locking sync is a separate initialization to the comfort/central locking controller. One user saw both keys recognized in EWS via INPA, yet the remote functions still failed. Re-initialization targets the locking controller, not EWS. [Elektroda, Chupacabra, post #17152157]
How many BMW E46 keys can I program?
Up to four remote keys. Initialize each additional key within 30 seconds after the previous one. If you skip the window, restart the sequence and include all keys you want active. The car confirms success by cycling the locks. [Elektroda, Chupacabra, post #17030544]
Can an aftermarket alarm interfere with factory remote locking?
Yes, if it was spliced in. In the thread car, locking with the blade armed the siren, and unlocking by blade triggered it because the remote wouldn’t disarm. However, if the locks cycle during initialization, the factory module hears the fob; focus on the transmitter or battery. [Elektroda, Chupacabra, post #17030162]
How can I test if my E46 key fob is actually transmitting RF?
Confirm RF output before more coding. Use a key tester, RF receiver, or ask a locksmith to check. “Start by checking if the remote control emits radio waves after replacing the battery.” If there’s no output, address the fob hardware or battery type first. [Elektroda, CameR, post #17030508]
Is using a 3.6V rechargeable coin cell safe in an E46 key fob?
A reported case showed a 3.6V replacement measuring about 4.0V, after which the remote stopped transmitting. Use the correct 3.0V-rated cell and verify voltage under load. Overvoltage can damage the RF section. If you installed 3.6V, replace it with the proper cell and retest. [Elektroda, Chupacabra, post #17096656]
INPA shows my keys in EWS, but the remote still won’t lock/unlock—what does that mean?
It means EWS recognition and engine start are fine. Your issue is with the remote portion or its pairing to the locking controller. Re-run the initialization sequence and confirm lock-cycle feedback. If it still fails, inspect battery voltage and fob RF output. [Elektroda, Chupacabra, post #17152157]
Do I need to program my key in an alarm control unit separate from the immobilizer?
Factory remote initialization targets the central locking/comfort controller, not EWS. Aftermarket alarms may require separate pairing, but if you can’t find that module and the locks cycle during initialization, focus on the fob hardware and battery. The thread car showed this exact scenario. [Elektroda, Chupacabra, post #17030162]
Can the comfort module need separate programming for keys?
The standard initialization sequence is the comfort/central locking pairing procedure. Success is confirmed by immediate lock/unlock cycling. If that happens yet the buttons later do nothing, suspect the transmitter or power cell, not the comfort module. [Elektroda, Chupacabra, post #17030603]
I have only one key and it won’t initialize—what are my options?
Verify the correct 3.0V cell and clean soldering. Test RF output. If still dead, visit a professional key service to evaluate the fob. “Go to the key manager and check if the key is suitable.” They can assess transmitter health and advise repair or replacement. [Elektroda, Strumien swiadomosci swia, post #17186508]
Will replacing the full immobilizer set fix a non-working remote?
It can in specific fault cases. One user replaced the full immo set due to an EWS fault; the new key’s remote worked and one old key also functioned. This is a last-resort path when diagnostics confirm EWS-related issues beyond the fob. [Elektroda, Chupacabra, post #17316731]
What timings matter during E46 key coding?
Turn to position 1 and remove within 5 seconds. While holding unlock, press lock three times within 10 seconds. Initialize additional keys within 30 seconds of each other. The locks should cycle once to confirm success. Re-do all keys in one session. [Elektroda, Chupacabra, post #17030544]
Why does my siren arm when I lock with the blade but trigger on unlock?
That behavior indicates the alarm arms with the central locking but never sees a valid remote disarm. With a non-transmitting fob, unlocking the door by blade triggers the siren. Restore the fob’s RF function or locate and re-pair the alarm brain. [Elektroda, Chupacabra, post #17030162]
