BMW E90 320D: Remote Control Not Functioning for Opening/Closing (Car Starts, Batteries OK)
Bumkaa 5607 2
  • #1 16442607
    Bumkaa
    Hello. For me, the car starts from the inside, you can close it, you can open it after moving off, it locks after you remove the key, but the remote control does not work at all, I have a second one and the same. Batteries ok and both. Someone wise can give some hints. Thank you in advance.
  • Check antenna connection and remote signal reception
    #2 16443354
    mysz777
    Help: 5
    Rate: 9
    I warmly welcome.
    Check if the antenna is connected, sometimes someone will not connect the ankle after disassembly. And how do you have what to check if the remote controls generate a signal.
    As you have access to the interface, it is possible to check if the signal is received from the transmitter after connecting.
    Then you will know if the problem is in the coding of the remote controls or the transmitter has completely spilled.
  • #3 16447611
    Bumkaa
    Tomorrow I will have time to bury at the car and if this antenna would be great, but a small hint where to look for this antenna.?
