LTE Play Router for 100GB in Poznań: TP-Link MR200 vs MR6400 for WR841 + WR740 Setup
kisielku 4407 8
  • #1 17031544
    kisielku
    I live in a block of flats in Poznań, I have a 100GB play card, so I give up cable TV,
    I wonder what router to choose, MR200 or MR6400, after the apartment I have a network made on TP-LINK WR841 + WR740, I paste a map with BTS and my location LTE Play Router for 100GB in Poznań: TP-Link MR200 vs MR6400 for WR841 + WR740 Setup
  • #2 17035685
    makosuu
    Help: 369
    Rate: 370
    Not far from BTS, on btsearch there is no verified LTE, there are only permissions, but there should be git. As for these routers - I would not take any. They are quite expensive and only category 4 LTE modem. What's your budget?
  • #3 17035802
    matek451
    Help: 4330
    Rate: 5753
    In Play, the minimum is a stationary router on which you will force specific LTE bands, eg B315, the optimal one is a router with LTE-A band aggregation. Two bands aggregate B525, E5186, three bands B715. Coverage from Play BTSs at Junacka 11, Górczyńska 48 on which LTE2600, LTE1800, LTE2100 and LTE800 bands operate with aggregation. At Radienista 87 BTS with LTE1800 and LTE2100.
  • #4 17036498
    kisielku
    As for the budget, the cheaper the better, but in those + -400 I would like to close myself.
    When it comes to range, somehow on the phone it is the latest DL 48Mbps UP 2Mbps tests
    It is also important that I have TP-Link TP-LINK WR841 + WR740 routers in my apartment, the 841 sends the network, and the 740 receives wifi and forwards (via wifi and RJ45).
  • #5 17036859
    makosuu
    Help: 369
    Rate: 370
    And what does this have to do with it? Now you will have one LTE router.
    You can buy Huawei B525 up to PLN 400.
  • #6 17037079
    kisielku
    Drug, is there a chance for a new thing? because as I see it is about PLN 600 new
  • #7 17037204
    makosuu
    Help: 369
    Rate: 370
    Used take, people take from T-Mobile and sell it right away, so it's basically new.
  • #8 17037614
    kisielku
    Ok. The only thing left is sim lock, right?
  • #9 17037713
    makosuu
    Help: 369
    Rate: 370
    There is no simlock. Such a thing has long been gone.
✨ The discussion revolves around selecting an LTE router for a 100GB Play card in Poznań, with a focus on comparing the TP-Link MR200 and MR6400 models. Users suggest that both routers are limited to category 4 LTE modems, which may not be optimal. Recommendations include considering the Huawei B525 for better performance, especially with LTE band aggregation. The user expresses a budget of around PLN 400 and seeks options that may include used devices to avoid higher costs. Concerns about SIM locks are addressed, confirming that modern devices typically do not have them.
