iPad A1430 64GB - the device does not recharge after discharging, does not start
adrianna82 7566 6
  • #1 17039116
    adrianna82
    Ipad A1430 - a few days ago it discharged to zero and I cannot charge it at all since then, it cannot be started.
    A drawing of an empty battery appears, then when I turn it on, it shows an apple holding up differently
    long, sometimes many hours and does not disappear. Then it disappears and shows itself again. Even after many hours, the tablet cannot be turned on on the cable, the battery icon still appears.
    Any ideas how else you can revive the equipment? Replacing the cables did not help, I have two original ones ...
    Thank you for your help!
  • #2 17039147
    KapitanSTS
    Level 30  
    Help: 115
    Rate: 274
    Note at the beginning - if your device has discharged and was left unloaded for a long time, it often needs at least several dozen minutes to charge and start up. However, if you have been charging the iPhone for a long time and the screen remains black - restart the device connected to the charger.
    How to reset iPhone / iPad
    Press and hold the Power button (top or right) and the Home button (round, always below the screen) at the same time. Keep pressing the buttons until you see the Apple logo, at least 10 seconds.
  • #3 17039234
    adrianna82
    I've tried that before - it doesn't solve the problem. The apple logo appears, then the empty battery icon disappears.
  • #4 17039288
    nutergsm
    Help: 1034
    Rate: 1663
    Take the device apart and check the battery voltage. It may be necessary to recharge it with the service power supply.
  • #5 17040333
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Do as nutergsm says, or there is also option two, disconnect the batteries for 10-15 minutes and reconnect. I had 2 pieces of iPads with the same symptoms and it helped.
  • #6 17047963
    adrianna82
    Ok thanks for the tips.
    I don't know if I can handle opening the device, there are a lot of videos on yt, but it doesn't look very easy. Do you have a patent other than the one shown in these tutorials or is it better to give it to someone who is skilled in it?
  • #7 17048017
    nutergsm
    Help: 1034
    Rate: 1663
    If you have doubts if you can handle it, give it to someone who knows it.
✨ The iPad A1430 (64GB) is experiencing issues where it does not recharge after discharging completely. The device displays an empty battery icon and intermittently shows the Apple logo without powering on, even after prolonged charging. Suggested troubleshooting steps include ensuring the device is charged for an adequate time, performing a hard reset by holding the Power and Home buttons, checking the battery voltage, and disconnecting the battery for 10-15 minutes before reconnecting. If the user is uncomfortable with opening the device, it is recommended to seek professional assistance.
